As we all know, hydraulic brakes have a better braking performance than mechanical brake.Too many E-bike fans would like to use hydraulic brake replace of the normal brake. Usually we met some troubles in the process of their hydraulic brake conversion with papamotor kits.
1 Hydraulic brakes can’t be mounted to the original bracket of their mechanical brake.
2 The space between the hub motor cover and brake rotor is not enough for placing the hydraulic brake caliper.
3 Non-international standard adapter won’t be compatible with the disc brake rotor.
4 Hydraulic brake doesn’t have the function to cut off the motor power.
I squeeze some time to mount a rear hydraulic brake (Shimano BR-M446) to my E-bike this weekend.
Material configuration as below:
Bicycle (GIANT ATX690) *1
26inch Rear motorized wheel *1
Disc brake *1
Shimano BR-M446 hydraulic rear brake *1
Some necessary accessories
My solution to the above 4 questions:
Q1. Hydraulic brakes can’t be mounted to the original bracket of their mechanical brake?
a Use F160 bracket to replace of the original R160 bracket.
b We have to make some modification on the basis of original brake bracket.
Q2. The space between the hub motor cover and brake rotor is not enough for placing the hydraulic brake caliper?
a Shorten the original axle spacer to 18mm first.
b Due to the size of fixed brake caliper is too thick, it’s almost near to the hub motor cover. So we have to use a special designed 4mm spacer to lengthen the space.
Q3. Non-international standard adapter won’t be compatible with the disc brake rotor?
We use a special designed 10mm adapter, which is suitable for installing 44mm diagonal Shimano brake rotor
Installation steps:
Besides, we also install one pair of torque arms for the safety.
Q4. Hydraulic brake doesn’t have the function to cut off the motor power?
The Shimano446 brake handle can’t cut off the motor power, so we choose to install one right E-brake handle which can cut off the motor power directly.
