That's great Spinningmagnets!
Still i'd like it cheaper before I order. But indeed, I'd like to order this week. If there are only us that are interested at that price, I'll order four and take the rest as spares.
As the price of the higly intergrated V3 Adapter would be quite high, I try to lower cost by separating it into more and simpler parts, that can be machined much faster. This way it's also higher value, since it can be used in other drives that differ from mine. The final distances and sprocket interfaces can be simply swapped using a different assembly. Using a common interface, there can be a construction kit for sprocket adapters for different freewheels, sprockets and shafts.
The interface I chose is four M4 screws, 10mm offset from the center. What do you think?
The shaft interface will fit MAC, BMC and all Bafang Motors as far as I know.
