Teaker68
Noobey here, looking to see if anybody has built a Fat Tire Bike utililizing a Bafang Mid Drive? I know they can work with two different bottom brackets and cranks but not something this wide that I know of.
WOW, good find! $3500, ain't cheap, but if they are making one, others will follow.motomech said:Eco\speed makes a Fat Bike mid-drive. Didn't see a price, but I'm sure it's not cheap. Might give you some ideas.
http://fat-bike.com/2014/03/press-release-ecospeedfatback-electric-fat-bike-announced/
spinningmagnets said:lectriccycles is a US dealer for BBS02's, and their store carries a fat bike with the BBS02 already installed (no suspension, $3500). I don't know what brand of frame it uses, or how wide the BB is. I suspect it has a 100mm BB, and lectriccyles is locally making a custom bracket to mate the two. I think he was smart to be an early adopter of both the BBS02 and E-fatbikes.
http://lectriccycles.com/products/chubby-750
MikeFairbanks said:Why mid-drives? Wouldn't it be easier to just add a hub motor and rebuild the front or rear wheel?
XiongDa 2 speed might fill the bill.tahustvedt said:MikeFairbanks said:Why mid-drives? Wouldn't it be easier to just add a hub motor and rebuild the front or rear wheel?
I initially wanted a hub motor for the front wheen to give me more traction in deep snow, but decided against it because of the torque required to drive a 29" diameter wheel at low speed with high efficiency. Are there any 250 W hub motors that work efficiently at 100 rpm? With the current tires my wheels are 735-740 mm diameter, which is about 29".
