Before we can do much to help, we need to know where you are starting from.big said:kindly post you suggestions and tips to start designing the motor
big said:Anyone have any Idea about building a Coreless brushed dc motor?
Well, I couldn't recommend a coreless motor if efficiency is one of your goals.big said:Anyone have any Idea about building a Coreless brushed dc motor?
Possibly that to can work unless the efficiency and torque is great enough.Unread postby speedmd » Sat Jan 24, 2015 11:49 am
Would PC board type fit your requirements. Light weight for certain.
big said:I just need to go through PANKCAKE type motor as suggested.And I have gone through litz wire ,and I would hop to build it via using high gauge enameled copper winding wires to build the cable bunch for the rotor winding.I hope that would reduce Eddy Current and increase flux density.
And I have Gone through Lebowski's Motor and I found it to be Brush less and I am planing to build a brushed type,Since I would be able to go with low cost and simple Brushed controller than 3 phase complex controller for the motor.
big said:I know its going to be a hard design,But I have to some how build it.
As Specified earlier I have to keep the cost low without compromising efficiency ,so a Pancake type dc motor is all that is required now.
major said:big said:I know its going to be a hard design,But I have to some how build it.
My point is: The commutator can be the determining factor in design criteria such as RPM, # of poles, # of coils, conductor size and shape, etc. These things will then influence the magnet and coil design. Also, examine the loss and cost associated with the commutator. I suspect for a one-off build or low volume production, the AC controller is the lower cost/higher efficiency choice.
Honk said:I think you just mixed apples and oranges.
BLDC vs Coreless is not two different topologies.
You can have both "BLDC and Coreless" and "Brushed and Coreless"
BLDC means Brushless DC and Coreless is an elimination of rotor iron.
Honk said:In my bok a coreless design is eliminating the iron for the windings.
Perhaps I'm wrong but the idea of coreless is a lightweight rotor with low inertia.
When having a magnetic rotor it needs some backiron to enhance the flux strength
Magnets + backiron = high rotor inertia.
But using the windings as rotor doesn't require any backiron in a pancake motor = low rotor inertia.
Not totaly brushless, :lol: car generator.major said:Honk said:In my bok a coreless design is eliminating the iron for the windings.
Do you have, or know of, a BLDC with windings on the rotor?
