cwah
Alan B said:Front Brake Upgrade
First the Gatorbrakes, when they were first installed:
Now the new Tektro brakes:
Today I began the Borg's upgrade. I decided to install the new front hydraulic brakes first. This week looks like a good dry one for commuting, so I didn't want to disable the bike by tearing it too far apart, and swapping out the front brakes seemed like a good start.
Why upgrade the already good front brakes? I've asked this question myself, and others have asked it as well, so here's the list of differences:
from 4 pot Gatorbrakes to Tektro Auriga Ebrake
both are dual caliper mirrored caliper design (as required by forks)
from 160mm to 203mm diameter discs (more braking power)
from 1.6mm thin to 2.3mm thick discs for better thermal management and reduced stress
easier alignment process (pillar setup on new calipers)
hoses too long vs hoses cut to proper length (could have fixed this)
stainless steel mesh hoses vs plastic hoses (this was the one step down)
additional feature: ebrake switch
additional feature: parking brake
additional feature: adjustable finger reach
The new pads appear to be more available (Gatorbrakes aren't as mainstream)
Out with the old and in with the new, the test results are in. The new brakes are ... excellent. The stopping power feels better. Noticeably better, with less lever pressure required and still good modulation. Not that the Gatorbrakes were bad, they did a good job. But these feel a bit better. Maybe it is just because they are new. But those thicker larger discs are quite a bit more substantial and should help with heat dissipation. The real test will be after a few commutes, and descending the 15% grade therein.
I have not employed the brake switch yet, that will be done later on. The parking brake is quite handy for stability when the bike is leaned.
are these front brake adaptor? I have rim brake on the front and I need to find a way to fix disc on it
