methods
1 GW
I just made up that title because I knew it would arouse Luke
So I finally finished my long-awaited 24 fet controller run and I was looking for a way to burn them in before releasing Beta units. It just so happens that I know a guy who has a fetish for blowing controllers and motors... so I packed up my Jeep and headed over there. Here was the Setup
CroMotor laced into 20" on crap rubber
24S 20Ah Pack with a top-off charger running
My super-pimped 24fet controller programmed to 150A DC and 300A Phase
All of this was bolted into my KMX trike.
I really thought I had a setup that would be great for exercising the controller. Turns out I was totally wrong... we could not even get the controller warm and the room was reeking of smoking hot laminations :?
EDIT: LOADED UP MORE VIDEOS
CroSmoker Dyno Videos
10hp to 2hp sweep
[youtube]1Ori-OBUMmg[/youtube]
10hp to 3hp run
[youtube]SNeZvyovgTs[/youtube]
10hp to 5hp rip
[youtube]4nhgZeBcgRo[/youtube]
7hp continuous run
[youtube]giw0sW_xCUg[/youtube]
10hp continuous run (original post video)
[youtube]dAj_CM8aoWI[/youtube]
methods clowning on Lukes motor blowing fetish
[youtube]3RZySSdM6qQ[/youtube]
So... yea
We really had a hard time getting the motor to load the controller enough at 100V. I wanted to get in a 15hp run but to do that I think we are going to need to change a few variables. I have a ton of Dyno Data for you guys to sift through We ripped it a bunch of times and just kept cranking up the load - cranking up the load.
So we calibrated the shunt in my CA (8W shunt)
The Videos capture the mechanical output as well as the CA data - so with that you can calculate efficiency and no doubt you can also ferret out the point at which we were saturated.
Here is what the guts of my prototype look like. Notice that I moved all of the heavy wiring to the bottom of the board - this totally cleans up the top of the board leaving room for either very easy troubleshooting or 2X the Electrolitic capacitors. All those "surf boards" you see are my favorite 250V 1.2uF caps in 4P - so 4.8uF each. Notice that they are strung from the Source of one bank across to the Drain of the other bank. This was Big Mooses idea - though I am not sure if I implemented it how he intended for me to. Anyhow - I have more ultra low ESR caps on this controller than anyone has ever had. Forget that Poly crap... these caps are tiny.
Yes I know the leads are not optimized yet... the original plan was to solder the caps right down on the board but they started popping on us like popcorn - too much flexing on the PCB - to these boards decouple the sensitive caps from all that motion and heat.
To give you a sense of scale that is 6AWG stranded on the traces. The phase wires are 8AWG noodle and the power and ground are dual 10AWG noodle.
The hot rail (the high side) has a 70C thermal cut-out. I was eager to try it out but we were hardly even able to warm the controller up even after a few hard runs.
I know I have already posted these pictures a couple of times but mmmmm... would you look at the color of those housings? It just makes my hubgina lube up.
So... to the point. Attached is some of the dyno data. I am not sure which runs these were (have not even looked at it) but I think there is some good data in here. It wont be quite as useful until I post the Video with the matching CA data so you know power in.
Raw Dyno Data for download
(note - there was significant traction issues so take that into account while evaluating the data. You can probably hear when it grabs in the video)
I am at this moment waiting for the video to email from my phone to my computer. Dude.. dont ask. The USB is broken and I dont have a uSD reader right now so my only option was to email the 20M movie to myself :x
When we finally loaded it down so hard that it was just groaning we managed to eek out 10hp mechanical. I dont recall completely off hand but I think that was with about 15kw going in. Video or it didn't happen right? Uploading...
So I am actually really surprised and disappointed with how how quickly we had to quit due to CroSmoke filling the room :x This motor absolutely needs to be oil filled ASAP if we have any hope of doing some meaningful testing for my controller.
Until then - I dub my controller the "CroSmoker" until proven otherwise.
(though thankfully I was able to shut Luke down before he managed to actually smoke my personal Cro... for which I do not have a replacement)
(Ok - I have 3 replacements but I would rather sell those to you fiends and buy tires for my Jeep)
Lets see who the first is to have the time to pick through the video and plot the input power vs output showing eff.
I will upload the other videos if more data is needed.
-methods
10hp to 2hp sweep
10hp to 3hp run
10hp to 5hp rip
7hp continuous run
So... yea
-methods
