parabellum
Will only recommend, software programmable controller if you want to play with different voltages, so you don't fall as victim to LVC and HVC (for regen braking) limit
Lebowski said:maybe with all this power it's better to replace the basic chinese bicycle for a more sturdy one![]()
parabellum said:I started just as obsessive like you with cellogs, bm6s, cellmeters etc, then I noticed that they are not really useful, even worse, they disballance your pack. Now all this meter stuff is garbing dust and I bulk charge and discharge my batteries, checking the top balance with MKS propo from time to time. I can go over 20 cycles with less then 0.04V balance difference(in 24s pack). If you permanently connect cellogs, prepare to balance charge the pack about daily or so (depending on capacity)
Edit: I also doubt you will notice some efficiency difference between 20s and 10s if you install 3 speed switch. What I mean is 20s 50% speed limit is about 10s 100% if you go easy on throttle when accelerating in first case.
Exactly, it is a way to go.hjns said:However, it does seem reasonable to design the system so that I can easily connect and disconnect the CellLogs.
In performance, speed and efficiency 10S 20Ah controller limit, no throttle limit 100%= 20S 10Ah controller limit 50%throttle limit (If you ride this 2 settings, you will not be able to distinguish which is which, only difference regen braking will work down to lower speeds for lower voltage). Actually there will be 0-5% difference in efficiency, but it is kind of covered by lower wiring resistance loses in between battery and controller at 20S.hjns said:Are you saying that going full throttle on 10S4P 18Ah would be of similar efficiency (aka mileage) as going easy on the throttle with 20S2P 9Ah?
parabellum said:Only issue, 3 speed switch is limiting throttle not current, so it is up to you for efficient ride.
hjns said:parabellum said:Only issue, 3 speed switch is limiting throttle not current, so it is up to you for efficient ride.
Thanks again! I should be able to limit current in the CA as well on the fly by adding a potentiometer, right?
hjns said:and in the pictures the copper wire is visible that makes the soldering much much easier
parabellum said:So, you just tie short ends with cooper wire and then sock with solder?
