methods
1 GW
I would go to the Technical Reference Area
http://endless-sphere.com/forums/viewforum.php?f=16
It really depends on how hard/how long you are going to run at the elevated currents. Of course you can run 100A for a few seconds as it is - but the longer you run the hotter things will get and the more losses you will have in the traces.
For 60A I would just solder the shunt - remember that you need to have a way to re-calibrate after you do this. A little solder goes a long way too... You dont need to bridge the entire thing.
If you want to go 80A or 100A then I would suggest adding a little more copper to the traces. To determine which need to be beefed up just look at the board. What was already beefed up? But even better... You really should take the time to understand what you are beefing up and why. Once you understand what is going on in there it will make a lot of sense.
So following those traces..... Find the main power in. You have +V and GND. You will find that one of those giant traces goes right to the +V input. The other goes to the GND input. The only other "Heavy" places are where the three phase wires come in. So this tells us that power comes in on V+ and GND, travels over to the row of mosfets, and then out the phase lines. These are the places that need heavy gauge copper. Something equ to 12AWG should suffice.
These come with IRFB4110 fets, 100V caps, 36V to 150V regulator, and built up traces. So besides soldering the shunt and maybe adding some copper to the power traces if you want reliability I would add another 1mF of capacitance to the main rail. You see the biggest capacitors? The ones marked 1,000uF 100V? I would add another one of those (or two). Keep the legs as short as possible. These things are your insurance. You dont need more to make it work but adding more will make it much less likely that you will blow something up.
Make sure any copper you solder to the traces does not contact the housing. Even just adding another 22Gauge wire does a lot - as it gets coated in solder and adds bulk.
-methods
-methods
