ElectricGod
I've cut a "D" shaped hole in the bottom of the battery box and made an aluminum plate that fits over it and seals with foam weather stripping. The pan head screws stick out a little, but the plate is almost exactly flush with the trim around the bottom of the box. I'll get some stainless counter sunk screws later to make it all sit flush. There are 6 threaded brass inserts in the plywood for closing up the access panel. I am now able to arrange everything inside the front section and get it into the space that's there. I discovered a small wiring mistake in the process. My main switch that turns on the controller and electronics draws batt+ through the motor controller rather than straight off of batt+. The problem is that the wire going to the controller and the connector that it is soldered to was not designed to handle more than an amp or so. with all the lights on and the horn, I'm pulling 4-8 amps. That wire won't hold up for long! It's a minor fix which I'll get to this week. I have a deans connector for the peripheral stuff that comes off the battery feeder lines that I will add a wire to that goes to the main switch. I'll just connect to this to fix the problem. Everything was working, so I didn't detect my mistake before now. It was only because I had removed the battery box and partly disconnected things that it became apparent. Despite my efforts to push everything into the front section, the Graphene pack and a Multistar green pack just wont fit in the length that exists. I need maybe another 1/2" to make it fit. I have an idea that may work. There's a 1x3/4x6" piece of pine just under the lid hinge for reinforcement. I may be able to remove it and make a much thinner version out of hardwood such as maple. This would allow the graphene pack to slide forward about an inch and give me the space to fit the Multistar pack in the bay. Otherwise, I have lots of older LIPO cells from my first battery build for the blue scooter that are just sitting around. Over the weekend I put together a 16S pack made out of them. It fits in the space easily, but they have limited capacity and life unlike the brand new Multistar batteries.
This is the access port in the bottom of the battery bay.
