marce002
Hello
A motorcycle VOTOL EM50, was fine and ok for 3 months 70kmh ok... then suddenly have : soft start barelly keep going and sometimes CUT OFF happens,,, fast start ends up in cut off..... no battery problem, swapped controlled to stock one, and all is fine, so the issue is inside the votol controller, my question is :
since all seems to be crystal clear no signs of damage at all, can it be the mosfets despite they are all measuring ok with diode mode multimeter, (in circuit test, i did not take them appart).... was using 96V max volt specs though..... caps seems to be ok too..... what else to llok??? should I take mosfets appart to be sure thay are all ok?? what is the chance some mosfets have ruined even in diode mode and resistance look are identical (neg and positive group of course)
