Photon q factor starts at 200mm for 73mm, and up to 230mm (or 240mm, the documentation is inconsistent) for some of the wider 120mm BBs.Wait... does the Photon really have a 190mm Q-factor? That is the same as my BBSHD with straight cranks. I, personally, would not be bothered by such a wide stance, but I can see why others would be alarmed and turned away by that. They should have shot for 170mm which would be about standard for mountain bikes.
Not possible, the offset is -0.6mmCan the Photon be positioned symmetrically on a 73mm BB? I think I saw in this thread somewhere that it's possible.
But, AFAIK fairly normal for add-on mid-drive motors. I measured my BBSHD (68-73 version with stock crank arms) at 195mm, and if the bike being electrified has a wide chain stay geometry for mid-fat tire clearance, you'll likely need a wide Q stance. 200mm is admittedly a bit much on a 68mm BB, like this minivelo bike (for which I wish CYC offered a 68mm spindle):200mm Q-factor on a 73mm BB shell is insane. Damn.
Except in the Photon manual, the Q factor is listed as 240mm for BSA120. So possibly some discrepancy there.Here's CYC's Photon dimension table:
It's fine. With narrower Q I find my feet tend to be slightly more outboard on the pedals anyway. For hardcore rock gardens and technical terrain the wider Q might be a problem, but I don't ride much of that and also have shorter cranks anyway.200mm Q-factor on a 73mm BB shell is insane. Damn.
Well, it's probably fine for me too, but I have a very wide frame/bone structure. I'm just shocked to learn that the Photon is worse than a BBSHD. That doesn't seem to align with the target demo for the Photon.It's fine. With narrower Q I find my feet tend to be slightly more outboard on the pedals anyway. For hardcore rock gardens and technical terrain the wider Q might be a problem, but I don't ride much of that and also have shorter cranks anyway.
It is worth noting that the ISIS standard itself may be contributing to that. Although it isn't explicitly specified in the standard, the crank thickness at the shaft is about 27mm minimum (18.5mm for the splines and clearance, and 8.5mm for the removal thread), which is 54mm when you add both sides. Other proprietary standards (like SRAM DUB) use much thinner crank ends (20mm) to get the Q factor down. That's a difference of 14mm just there.Well, it's probably fine for me too, but I have a very wide frame/bone structure. I'm just shocked to learn that the Photon is worse than a BBSHD. That doesn't seem to align with the target demo for the Photon.
Wait until I tell you the whole ebike with battery weighs 21.5...Holy cow, and this is your hottest month? That's like room temperature.
I sincerely don't understand this reply.Wait until I tell you the whole ebike with battery weighs 21.5...
This makes a bit more sense:I sincerely don't understand this reply.
I'm not disparaging you or New Zealand. I wish I could live there. It's just that it was not what many would consider a warm day, and you live in a very moderate climate:
I have torture tested my BBSHD in 40C weather... now that's a motor that can survive anything. When I see reports of the photon in actually hot weather, I'll be impressed.
Any additional data is appreciated, but I'm not sure this ride dispels overheating concerns. But it is great the only issues you are having is a loose crank arm and slightly more motor noise than desired. Have you tried retaining compound at the splined interface?
I was quite surprised at the weight of my sister's Merida eONE SIXTY, size small. Rode like a tank. Mine isn't particularly light - being a midfat bike with basic spec there is a lot of room for improvement, but I think the Merida was 3-4kg heavier.Kg no doubt! Not bad but that isn't what I would call light. My Cannondale Photon conversion is similar. I guess they are light as compared to many of the commercial offerings.
What battery are you using?I purchased the brake sensors and headlights. I'm not sure I needed them. The brake sensors were a bit challenging to install because my Shimano MT200 brake levers didn't have an obvious place for the sensors. I figured it out by inverting the sensors in the app. So when I pull my brakes, the magnet comes toward the sensor. I also had to use super glue because there was no option to zip tie the sensor to my lever. It works okay. Oddly I found that with both brake sensors installed, the system only picks up the brake signal when both brakes are engaged. In other words, if I only pull the back brake, the motor does not cut power.
With that said, I don't pedal when braking, so the motor isn't outputting power anyway. I probably didn't need the brake sensors. If I were to do it again, I'd skip the brake sensors and get a 2 channel wire harness (you need the 4 channel one if you get the brake sensors).
I installed the throttle, but I don't enjoy it. it reminds me of my kids' electric scooters.
I took the bike on some steep hills and it handled it well... on level 3 pedal assist. Level 1 and 2 left me gassed. So, I might have to adjust the pedal assist levels a bit.
I'm using a 52v21ah LG jumbo shark battery from Golden Motors. It's pretty cold in Toronto this time of year, so my range isn't amazing. I did a 20km ride today, with a 1km ascent (Gates Gully for my Torontonians). The battery went from 57.x to 53.x. I was using pedal assist 3 the whole time, maxed at 750 watt. But it was closer to 400 watts assistance generally.What battery are you using?
Like you, I was looking to future-proof and got brake sensors, but decided they really are not necessary IRL and never fitted them (I also have MT200 brakesets, the additional clutter would have looked quite ugly). I think with decent torque sensing you don't need brake or gear sensors. I'll probably change out my 1:4 harness with blanked off connectors for a 1:2 harness, next time I order something from CYC.
I did fit the throttle, and that is really useful for short bursts of power if required (I use mine mostly off road). I never really use the throttle for extended distances, it just eats into battery and range far too much.
I find that even with 34t chainring, I'm usually going far faster than anybody else on ebikes since CYC isn't speed limited but most OTS ebikes are (in NZ we have a power limit of 300W for ebikes but no speed limits, other than the posted limits, of course).
