Without specific manufacturer data and efficiency and performance charts there is only one metric that matters with this particular motor... whatever keeps it cool. Beyond that, how on earth would we know its ideal voltage? The rated voltage is 36V – 52V, but what does that tell us? It is looking like 48V and 52V don't mix with human PAS well.The more you gimp an electric motor vs it's ideal voltage, the more efficiency and power you lose. It may be a 350W nominal motor on 36v :/
What you're missing is that you are running both at full throttle. Of course the 52v one is melting down, it's going faster and thus using more power. That's not a fair comparison. You can get the same performance from the 52v battery with the bbshd by just by lowering the throttle level till you're at the same speed/rpm as the 36v battery. Which is what I did in the link I sent earlier. (Hub versus mid should make no difference, you can try it yourself, lower the throttle of the 52v side until it matches the rpm of the 36v side) Which had the exact same performance. At a given speed/rpm identical motors will perform identically regardless of voltage. So instead of buying a 36v battery and lowering the power limit to 360w, keep your 52v battery and lower the power to 360w. It will perform identically.![]()
Here at 36V, the BBSHD perfectly matches a comfortable cadence and class 3 28mph. Again, at 52V, the BBSHD is significantly hotter, and significantly less range. Is there a problem with the GRIN simulator? What am I missing here?
I'm very surprised the BBSHD responds in this manner. Mid drives that contain multiple sets of gears probably have some other factors in play such as, when you lower the voltage, you also lower the gear friction.
I'm wrong and the reason is because i think in hub motor too much.![]()
You've chosen a different controller though. The MOSFETs could be higher resistance on one versus the other etc. Unless you're swapping out controllers on the photon you've got to do it with identical hardware.And look at this one:
36V at 25A and 911W of battery power
vs
52V at 18A and 912W of battery power
36V is more efficient AND putting down more actual power from the motor.
36V MTR PWR 696W
52V MTR PWR 685W
So we are basically only getting better voltage sag relief from 52V and higher RPM. But a high capacity 36V battery will help with that too. For the same amount of cells... 10S, 6P is only 4 more cells than 14S, 4P.
I am beginning to question the 52V hype.
Talking purely hypothetical but lowering the throttle on a higher voltage setup to get it to the same power/rpm as a lower voltage one would indeed result in some PWM losses but then higher voltage lower amps would result in less I^2R losses. Not sure how the two would cancel. I imagine any difference would be slight and it's definitely not worth buying a whole new battery pack for!Partial throttle also eats a little efficiency so it's not always great to use for comparison.
Good catch. Accident on my part.You've chosen a different controller though. The MOSFETs could be higher resistance on one versus the other etc. Unless you're swapping out controllers on the photon you've got to do it with identical hardware.
Very interesting; so as long as the lower voltage battery can deliver the power, then at the same power battery voltage does not matter to within a fraction of a percent. You are drawing a lower battery current though from the higher voltage battery.
Maybe that is why CYC didn't design the photon to run up to 72v? It is a different philosophy to their previous more Surron like motors.I am having a hard time seeing the advantage of 52V over 36V for a small PAS motor like the Photon. I wish they would publish their power curves.
ps by adding acoustic material to the bikee mid drive you would be reducing it's heat shedding capability but as we can see it has gobs of it, i was really surprised to see heat making it into your frame due to that mount you designed.
Liquid cooling or less power seems like the saving graces for the photon.
This in spite of all the negativity you might have seen here from one self described weirdo ignored person. Nor did the q-factor make me ride like an arthritic duck as posited by one yeti-sized commenter. IOW, I had an absolutely great freakin' ride.
I want to say thanks to everybody who has contributed to this discussion. I've been on the fence about buying a Photon for the last year or so. I still am on the fence. I appreciate different points of view even if it makes the decision more difficult.
It apparently works for some people and not others. Its good to know under what circumstances it doesn't work well.
Thanks everybody.
Why? The Photon is an outrunner motor which would indicate that there will have been totally different decisions made during design, partly due the the intrinsic higher torque and the heat dissipation problems that go with the configuration.probably a BBS01 on 500w power would be a good substitute.
I think your experience is standard - my settings always seem to get wiped, which I think is fine if you look at this from a product support POV. I've suggested a few times that the ability to save (and share) our own profiles would be really useful and would offset the reset done by firmware updates. Please, CYC...So I did the firmware update a few weeks ago and am just starting to get back to riding following my hip replacement, which is doing fantastic, and found that my settings seem to have been wiped and everything is back to factory. Anyone else? Not a big deal since I mostly ramped up the throttle to be full power for all the levels in race mode since the only time I use it is for brief beyond pedaling speed runs. Easy enough to go back in and fix that. I haven't looked yet bit was wondering, is there perhaps some way in the app to save those settings before doing updates?
