I think we are overloading this Photon thread a bit with other stuff, but maybe that's ok.
On the topic of thermal issues: my 48V battery measures 0.13 Ohm internal resistance (from the difference between idle voltage and voltage while discharging with a known current). So, at 250 W and 5 A the battery only has to get rid of about 3W, and all should be good, even when keeping it inside a closed pack. But hypothetically, at 750 W the loss would be 30W, and for a battery surface area of about 1/10 m^2, and heat transfer coefficient to still air of say 5 W/m^2/K, Delta T to shed the heat would have to be 30*10/5=60K, so 60°C or 140°F above ambient. That's hot!
So, is this battery no good for 15 A, or is this internal resistance of 0.13 Ohm for a 13s6p pack normal, and the battery needs to be mounted outside in the air stream, or what? Maybe I should find a battery thread to ask this in, but I thought I ask here first since we are already on thermal topics.
Update: after looking for discussions of internal battery losses and heat, I remeasured the internal resistance at the lower voltage of 48V, instead of the 54.4V where the 0.13 Ohm were measured: at 48V the internal resistance of the pack is 0.08 Ohm, so the battery power dissipation at 750 W comes out to 18 W, corresponding to a Delta T to non-moving air of 36°C or 97°F. That's borderline ok, although electronics (the BMS) lasts longer if it doesn't have to run that high (60°C or 140°F on a 25°C/77°F day).
Heat capacity also plays a role: at
conservatively 800 J/kg/K for lithium ion batteries, the fully charged 4kg pack would take 800*4/30=100 seconds to heat by one Kelvin, so 10 K in 15 minutes. After 45 minutes it would be 30 K hotter, but also almost empty. So this pack should not self-destruct even at 750 W.
