hjns
Hmm, beterschap!!
bart1006 said:Thanks!! I hope i can start work on it in the near future. I had a little accident with my ebike....
To much power is not always good
BiGH said:Damn you're right - Bluetooth is MFi; Bluetooh LE isn't....
Sigmacom said:I only just came upon this thread, but I have also been developing an Android app for the Cycle Analyst. I've started a separate thread on it here:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=59893
Keen to get some others to test it and any feedback.
bart1006 said:BiGH said:Damn you're right - Bluetooth is MFi; Bluetooh LE isn't....
Perhaps this one will work http://www.tinyosshop.com/index.php?route=product/product&path=65_110&product_id=705
At this moment i'm not at home but tonight i will try to connect to the jy-mcu perhaps it just works with BLE.
Will let you know!
bart1006 said:Well last week i tried to make a 0.9 version of the app
Perhaps some of you could try it to see if it works and to debug it!
Next week I'am starting with a new job in Norway so i will have a little bit less time to spend working on it.
In previous post you can see the functionality of the app.
You have to connect a bluetooth module to the serial output connection of the CA.
It has been developed en tested with CA V3 with prelim6 firmware.
It is possible to enter the bootloader and change between 3 the predefined profiles. You will have to use a logic level converter because CA V3 is sending bytes on 5v and the bluetooth module on 3,3v. And this will only work with prelim6 firmware because of a "hard" reference to the memory. If you don't have a CA V3 with prelim6 don't use the configure analyst button because it will change wrong data in the firmware/memory.
The LiveView will probably work without a logic level converter.
In the next version I would prefer to make it a more independent of firmware and CA V3 but for 0.9 version it will only work with the CA V3.
Without a doubt it will have some bugs so please try it and let me know what is going wrong!!
It lists the correct profiles but trying to change them crashes.
The logging seems to work well and I'm keen to see if you can get it to spit out something that can be put into Justin's trip analyzer
bart1006 said:It lists the correct profiles but trying to change them crashes.
Do you have configured the 3 profiles in the CA and which one? I will have a look at the code this weekend to check what could be the problem.
