madin88 said:oh i forgot to mention the e-brake
does it add further load on the regulator?
Baron said:Do you need an external shunt for the cycle analyst to read amps/watts, or does the cycle analyst use the controller's shunt for amp measuring? I have a powervelocity 12fet controller, the sticker on the side reads 2.02mOm
What is the purpose of the external shunts for sale for use with the cycle analyst?
If your controller lacks a CA connector, please download the Unofficial Guide here and check out "Appendix D. Adding a CA-DP Connector to a Generic Controller". The instructions there work for either V2 or V3 CAs.Baron said:I have a powervelocity 12fet controller, the sticker on the side reads 2.02mOm
Okay - took a quick look and saw similar weird numbers already in place on my bench rig...Marc S. said:I use a generic PAS sensor (PAS is set to 'AutoPAS' and 'PAS noTrq') and got some bogus values on the Human Stats screen.
HWhrs= -3284 and AvgHW= 3390 for instance.
Please examine the limit flags as described in section "4.7 Test Throttle and Limit Settings (Interpreting Limit Flags)" of the Guide. This will tell you what is causing the limiting and what parameter to adjust.derb said:When I set a current limit in the CA, the motor oscillates during the acceleration.
I have already changed the AGain value up and down but the oscillations remain, it becomes only sluggish or faster.![]()
The same if I set PowerLimit and change the PGain value.
justin_le said:Tats said:anyone got a definitive simple how to prevent pas surging?
WGain, not DSGain! You are in constant watts mode for PAS assist so it's your watts limiting loop that is coming into play.
Also, install the latest V3.1 firmware build once Teklektik posts it here. This makes the 3 position switch much easier to configure and doesn't require any 'hacks' to get proportional RPM behavior, you can explicitly set your relationship in Watts/RPM with the autoPAS mode.
3.1b12 should be out in the next few days - it's back in alpha test just now. We had an annoying bug show up a week ago that postponed things a bit.Stealth_Rider said:Are we close to seeing V3.1? I would like to use the 3 position switch configuration improvements. ETA?
hey marc-Marc S. said:I use a generic PAS sensor (PAS is set to 'AutoPAS' and 'PAS noTrq') and got some bogus values on the Human Stats screen.
teklektik said:3.1b12 should be out in the next few days - it's back in alpha test just now. We had an annoying bug show up a week ago that postponed things a bit.Stealth_Rider said:Are we close to seeing V3.1? I would like to use the 3 position switch configuration improvements. ETA?
Meanwhile, here's a teaser![]()
Although we had hoped to have a formal 3.1 production release out by now, things don't always go as planned. At this point we expect that b13 will likely be the final beta before 3.1 is formalized. So - soon - just not yet.Stealth_Rider said:I was thinking that based on Justin's post the 3.1 release was not a beta any more. Are we still working betas on 3.1?
I'm at 3.01 now so when I install 3.1b12 do I need to do anything special? I have written down my settings for gains, ramps, throttle in, throttle out, etc. so if I have to overwrite to go to 3.1b12 its no problem because I can put them back in by hand or using the Setup Utility.
This seems a variation of one of the techniques described in the Guide.Stealth_Rider said:I am wondering about this method for improving the value for Rshunt using a Satiator. Here's the plan.
derb said:Hello,
I have a Kelly KBS-E controller with ~ 100A battery current and would like to have a Eco mode with 40A via the Cycle Analyst (3.1).
I have installed the external shunt SH-1000-CA3 and the throttle signal is given by the Cycle Analyst to the Kelly Controller.
If I set no limit everything works fine.
My problem:
I have a mid-drive engine, no hub motor. If that is important
Can someone help me or has an idea what I can still try![]()
Sorry for my english (school is long ago)![]()
Thank you very much
teklektik said:This seems a variation of one of the techniques described in the Guide.Stealth_Rider said:I am wondering about this method for improving the value for Rshunt using a Satiator. Here's the plan.
Since you have a Satiator which has a charge current display, you might go at this more directly using the CA to directly view your charge current. Calibration is then a simple calculation.
See:
"6.10 Monitoring Charge Current"
"Appendix A. Calibrating the Cycle Analyst RShunt Value"
Stealth_Rider said:I'll continue trying out my AH comparison method and see how rapidly I converge on a value of Rshunt that give approximate AH equality.
'Only the Poles arrow flipping' is normal behavior - so that's good.jPas said:Lately I've had an issue with PAS not working most of the time.
In the Setup PAS Sensor menu only the right hand bar of the "P- D-" moves up and down.
On the Display #3 – Human Power screen it just displays 0 RPM.
