Hey, those 8mm bolts are just used as an example of how this thing slides around, can't be indexed, and does other funny stuff using 8mm bolts.
While i was out, i came up with a game plan.
I will cut 3/8" bolts down to 8.5mm by removing some of their thread.
If the threads are weakened to the point where they no longer with the bolt, then i'll drill the center of the bolt, tap it, thread another bolt through it.
This will fix the sprocket alignment issue.
It also mean i'll have a set of bolts to use with different sprockets if i chose to order from this guy again ( unlikely, but there are no alternatives at this time... )
