Sometime last autumn, Pack A which was hidden inside the Revive frame tube disconnected at the first cell. I pulled the pack out and I wondered if the frame tube pack idea was worth the trouble. I hadn't touched Pack A until now because I'm short on range. I thought it's time to get crackin' on my swing arm pack using my new enclosures.
The original cells tabs were weak so I decided to tear them out and solder fabbed copper tabs.
The negative tabs were welded really well and was a bit tricky to remove. I was left with sharp bits on the negative that need to be filed down. The positive tabs positive tabs pulled off effortlessly.
I found it odd that, if you remove the cell's paper insulation, that the whole cell body is positive and the negative is just a tiny island separated from the positive by just millimeters apart.
At first I couldn't decide on whether I should hold the pack together with duct tape or glue. I never liked the idea of committing the cells with glue and didn't want to wrap the whole pack with large and expensive heat shrink. What I want is to have the cells accessible (if I ever kill a cell again) and not have to tear into the pack and having to wrap it again with more expensive heat shrink. Duct tape was almost doable if kept to a minimum but it still gets sticky gunk all over the cells that gets stickier in summer heat. Well I shat me a brilliant idea so I brokedown and hopped on the hotglue bandwagon. Yep!
I've never used hotglue before and always wondered what the advantage of it is over using only a tube of silicone sealant. So I buzzed down the hardware store still wondering if I should pay 23 bucks for the hot glue kit or pay 3 bucks for a tube of silicone.. me being a cheap bastard..I asked for a tube of clear silicone. The clerk searched high and low, out of hundreds of sealant, silicone, glue products and he couldn't find one that was clear. I thought it might be God's way of telling me to go for the hot glue kit. And I'm an atheist! Well I was blown away by the convenience of not having to wait forever for it to cure. Instant gratification is so King. Shoot, now I have to find other uses for it to justify owning it... hell, I'm knee deep into this hobby so fuggit...
Earlier, I checked the height of the cell and it fitted nicely in the enclosure but my dumbass didn't bother to see if two cells fit side-by-side. I found that two cells were few a millimeters too wide and the enclosure wouldn't shut flush. So I staggered them and I'm in there like hardware leaving me with just enough space on the sides of the cells for the charging harness. shweetness!
So Dee Jay, what's this brilliant idea you've come up with this time?
After pulling Pack A out of the frame tube, I was left with the 1 meter long heat shrink tubing that I used to loosely insulate the pack and
Solid!
But Dee Jay, what if you kill a cell? That means you'd have to tear the heat shrink blah blah blah...
Fnck no! I can simply cut the tabs and viola! Slide that sucker out, and slide another one in! Tee hee hee!
~ Tra ~ la ~ la ~ I am the man.. 8)
Tuck the boys in bed. Nite-nite.
J
