Hi All
Right it's a done deal, the cages are being made for me this week and they are nearly identical to the last picture i posted.
A lot of good points there as always and after considering them all carefully i have decided to go with both batts mounted on the downtube.
I have been to the engineers this morning and shown them the same drawing that you saw at my last post - the engineer was a nice guy and said that the angled cage was a good design - cheers knoxie
the cost is £250 which is steep i know but being as all i have to is go back with the bike and let them fit it i dont think thats as bad as it might have been.
There are some minor changes to the drawing, the first being that the blocks on the underside of the frame are going to be moved to the ends to enable the batteries to sit right in the frame (previously the bottom battery would have had to sit on the bolt heads) this isn't a problem as i have space either end to spare and means the bottom pack sits snugly in the frame also.
secondly the frames are going to be made from steel, the aluminium frame would have been strong enough but the engineers concern was that ally is easily stripped if overtightened and i am reliant not only on 4 x 10mm bolts to hold it on but also 8 x 6mm alan key heads to hold the lids on too - given the size of the frames and blocks going to steel only increases the weight marginally and improves the threaded strength considerably.
thirdly the size of the angle is now 3mm thick and 25mm per side.i really didnt need 5mm in steel and the 3mm at 25mm wide is plenty.
the batts will be square to eack other not offset, offset would have been nice but it was close to impeding the forks and would require extra bolts - with straight on i can get away with four total to hold the brackets to the frame, so the end product should make my bike look like my signature exactly
i took the bike with me and one of the point 1 cells so the guy could really see what i was up to and how it will all fit together, there was a lot of questions about the bike and maybe i'll take it back there once im done to show them (along with the lbs and a few others who asked to see it when it's done!)
So, as a precaution i plan to line the bottom cage with a thin sheet of ally to protect the cell from debris off the front wheel - i do take on board the point about crunching the battery if the front wheel plunges but i will have at least 14" clearance from the ground to the bottom battery, thats more than enough i think, indeed my bash ring on the crank only has 9" clearance so we should be ok.
I'll post up some pics as soon as i get them done - should be the end of this week hopefully, a full days work for the guy.
I did take the cardboard model i made for the seat and although the engineer said he could do it it would be very expensive as it was time consuming, he suggested fibreglass and wood as alternatives but i'm not sure yet - i will get the cages done then i will wire the bike up and then finally i will get the seat made to fit and cover the controller (however this needs to be made).
Thanks for all the input guys - looks like my bike is finally coming together and i'll soon be ragging it at 72v 8)
cheers
D
