Hi numberonekiwi,
sorry, these are the arms that mark from teamhybrid supplied me when i bought my puma,i dont think he gets involved with the manufacturing,just supplies them with his wheels.you might try doug at evtech tho, i think and i emphasise THINK he supplied them to mark??????
i managed to get a ride today - but only under my own power
like knoxie mentioned the weather in the uk has been great (for uk) and it's been a bank holiday weekend of 4 lovely days
My own steam ride proved very useful as i found a few problems right off just by pedaling,not all bad news tho
i have a chain slippage issue,it only happens under very heavy load but i think the chain is slipping just one sprocket tooth,possibly the rear cog not holding the chain well enough?i'll post a pic of the rear sprocket in situ see what you guys think tomorow - as it said this only happens under really heavy load - pedal as hard as you can sitting and nothing - stand and give it all from off and i hear the dread clunk of chain slip,could be the wrong pitch either chain or sprocket too as i got the rear sprocket from mark and could'nt tell him what pitch i needed so he took best guess? i got the chain and the crank from the lbs so im not sure how i check this out?is there any way to measure them ?
My drainbrain is too springy on that clip,every time i hit the rough it makes like a woodpecker and if there were any numbers on i wouldn't have been able to read them !! lol no biggy, i will sort that out this week.
Anyways those issue aside i was really surprised and pleased by the way the bike rides - i went for a ten minute run to test the crank and make sure all was steady and i came home an hour later,lol.
starting off with the crank it really wasn't as bad as i thought it might be,pedaling was fine - nice smooth action and felt dead true under my feet,really nice and solid and oh how quiet it goes
i hammered it as fast as i could on road and sitting and all i could hear is the tread on the tarmac.Venturing into the forest and around the pond it behaved just as well off road, i really got lucky with the gearing - it's just a little harder than the gear i used to used all the time when i had the choice 27!! i suspect the weight of the hub is the only difference and as i said i pedaled? around for an hour and it was no biggy - don't get me wrong this is a mainly flat area with some very small hils and i wouldn't say i could pedal up the sort of incline that i could before the electrics,but to pedal it home would be no hassle whatsoever - i would even go as far as to say the bike is no more difficult to ride unassisted than some of the heavy bikes i had as a kid - the raleigh "grifter" springs to mind for those in the uk circa 1977 ish.lol
i was riding today with everything on, controller included, all i was missing was my lipo's and the most impressive thing was just how quiet the bike is.
it's the same setup as in previous pics with the controller on the downtube still but now bolted to the frame using one waterbottle hole and two zip ties which hold it rock solid.
i was expecting some rattles and bangs but not a thing!! no noise whatsoever except crushed forest leaves and wind - pre electric it used to clang no end over any rough terrain but the single speed and tensioner has totally eradicated it,very very happy about this as it didn't matter how much i tried the bike refused to make any more noise than a whisper of freewheel
talking of which again very nice coming home downhill i can honestly say that it was as good as my bike ever freewheeled only quieter!!!
checked the main cables throught the suspension and they were fine too - i did get the suspension to near max too so i'm happy now that it functions without being impeded.
Ok so chainslip aside very very pleased - all i need now is the usual sensible help to finish the electrics,the bike is fully wired and all i need to do is put the battery connections on the lipo's and i can ride under power for the first time
i didn't time to get the bike powered up this weekend for a couple of reasons,but one of the main ones is this is where i really need some help - i am a noob,i have lithium packs, they frighten me some.i want to get the connections right first time and i need to know the following...... help me out guys,after todays ride i'm busting a gut to get out there again
couple of shots of shunt mounting but then on to the elctrics and the questions i need some help with...............
