Display?
2old
Socal
The DM-03 Mini Display (25 amp controller) on a Bafang front geared motor doesn't seem programmable to remove the speed limiter and change the V from 54.6 to 58.8. Any recommendations for an inexpensive display that would allow this?IMG_6046.jpg
Is the display actually the controller, or is there a separate controller in the system. I see what looks like an alumin(i)um box on the top tube, which leads me to think there is a controller there. That's more likely to, well, control the system. What is it?
Pictures of labels and cables going in and out are useful, as it may be some re-branded item.
The aluminum box is the controller. I purchased the Bafang 48V, 500W Front Hub Motor Kit from Amazon, and it functions adequately with a Varstrom DM-03 Mini Display. It's just that I can't change the system to eliminate the 24 mph governor and would like the power to be generated more gradually and the system be 52V to match the battery so the voltmeter would be somewhat accurate.. The black box under the controller just houses the extra cables.
