jmygann said:Okay we got a simple front sus
Now the rear swing arm .... Chipman says ..."My design distributes load as wide as possible to keep weight down."
but he agrees that it might be better to have the motor off the swing arm ???
salty9 said:It would be nice to have the cg and weight distribution of the T-Rex.
..or both maybe ?JennyB said:... normal doors are hard to do both well and lightly. what about a polycarbonate bubble canopy ,...?
JennyB said:Yes. The Aptera looks nice, but remember the trouble it had with a 45 mph lane change in the X Prize?
The cg of a tadpole should be as low as possible and about a third of the way back from the front axle. Ideally, for a lightweight vehicle, that's where the driver's hips should be too. That's why I'm not keen on tandem tadpoles. Tandem deltas are a different matter: there the passenger sits right on the cg point, so has little effect on weight distribution.
Weight is the main thing to avoid. As Colin Chapman use to say "Simplify and add lightness." There is some relevant stuff on the Very Light Car blog. i also wonder is there's anything to be learned from microlight construction?
One thing I remember from the days long ago when I was interested in kit cars: normal doors are hard to do both well and lightly. what about a polycarbonate bubble canopy that slides forwards and down to make a windscreen for open-top motoring?
bigmoose said:....the green body above looks good for a single seater. Trying to keep the weight within the triangle with two abreast is going to be hard.
why so wide ? ... stability ? .. that is 14" more than a standard VW !jmygann said:VW Bj (ball joint) front suspension widened 6" ...51.6 inches +6"= 57.6" need to get out to about 78-80" ....
If done properly, it should.Pure said:Would making the vehicle able to lean negate most, if not all ill handling issues with a tadpole? Hell any trike.
bigmoose said:...... I know we head for a three wheeler because of the motorcycle licensing requirements; but if it were not for that anomaly, would we not head towards ultra light and 4 wheels?
