OK current BOM of the 'big stuff' (prices are in Aud, pretty much = USD)
Inductor: EK55246-341M-40AH from http://www.coilws.com/ $38.00 (yes, ouch!)
Bias Supply: http://au.element14.com/myrra/47155/power-supply-5w-15vdc-reg/dp/1825783?Ntt=182-5783 (MYRRA - 47155 - POWER SUPPLY, 5W 15VDC REG) $19.02
IGBT Current Sense Resistor: http://au.element14.com/caddock/mp930-0-020-5/resistor-current-sense-0-02ohm/dp/1612016?Ntt=1612016 (CADDOCK - MP930-0.020-5% - RESISTOR, CURRENT SENSE, 0.02OHM, 30W, 5% ) $7.72
Freewheeling Diode: http://au.element14.com/fairchild-semiconductor/rurg8060/diode-soft-recovery-80a/dp/9843930 (FAIRCHILD SEMICONDUCTOR - RURG8060 - DIODE, SOFT RECOVERY, 80A) $7.58
IGBT: http://au.element14.com/fairchild-semiconductor/fga25n120antd/igbt-npt-to-3pn/dp/1095025?Ntt=FGA25N120 (FAIRCHILD SEMICONDUCTOR - FGA25N120ANTD - IGBT,NPT,TO-3PN) $11.45
IGBT Driver: http://au.element14.com/international-rectifier/ir2125pbf/ic-driver-mosfet-500v-2125-dip8/dp/9101721 (INTERNATIONAL RECTIFIER - IR2125PBF - IC, DRIVER, MOSFET 500V, 2125, DIP8) $13.70
555 Timer for bootstrap: http://au.element14.com/intersil/icm7555ipaz/ic-timer-cmos-7555-dip8/dp/9663762 (INTERSIL - ICM7555IPAZ - IC, TIMER CMOS, 7555, DIP8) $1.26
PWM Controller IC: http://au.element14.com/texas-instruments/tl494in/ic-controller-pwm/dp/1470529 (TEXAS INSTRUMENTS - TL494IN - IC, CONTROLLER, PWM) $1.25
Comparator for Constant Current: http://au.element14.com/national-semiconductor/lm358an/op-amp-dual-low-power-dip8-358/dp/9486810 (NATIONAL SEMICONDUCTOR - LM358AN - OP AMP, DUAL LOW POWER, DIP8, 358) $1.76
Input capacitors - note ripple current ratings!: http://au.element14.com/kemet/alc10a331dc400/capacitor-330uf-400v-35x35/dp/1679496?Ntt=1679496 (KEMET - ALC10A331DC400 - CAPACITOR, 330UF, 400V, 35X35) $15.45 X 2 (or 3)
Inrush Current Protection Thermister: http://au.element14.com/ametherm/ms32-10015/thermistor-series-ms32/dp/1653452?Ntt=1653452 (AMETHERM - MS32 10015 - THERMISTOR, SERIES MS32) $8.34
Current Sense Resistor: http://au.element14.com/bourns/pwr4412-2sdr0050f/resistor-0r005-1-5w/dp/1435985?in_merch=true&MER=i-e1a0-00001051 (BOURNS - PWR4412-2SDR0050F - RESISTOR, 0R005 1% 5W) $1.97
Note that my design already reuses the bridge rectifier, common mode chokes (massive), and fuses + holders of the original Vectrix charger.
These would add a cost since you need at least a bridge rectifier, and common mode chokes if you don't want a transmitter.
Figure a nice 35A bridge rectifier. Common mode chokes - need to be able to handle 15A. Same place for these as the inductor.
PCB size is 150 X 200, this could be reduced - (those caps take up a lot of realestate on the PCB unfortunatly - the output cap could be reduced or omitted, but at the expense of a higher ripple and lower regulation - since a battery is across the output, this is not too major a consideration.) Going smaller on the input capacitance would require caps with a massive ripple rating - or you will boil them.
