I haven't built them yet, but some years ago I designed (ok, came up with an idea for
) the basics of a completely different "fork" that would give me more adjustable front suspension, and let me use some nicer shocks (taht I could swap out as needed), but I haven't made detailed plans or tried building it yet, because I don't have the "tree" clamps needed for it and building those is not in my toolset at the moment. (some time back, I had setup to buy some from a member here, but he sold them to someone else while I was asking him for a correction or confirmation to his paypal address
). (I also havent' had the time to do it).
These "forks" would actually be the four-bar-link "rear triangle" off a lightweight FS bike frame, mounted bakcwards (dropouts leading) and the shockmount/etc off the main frame, attached to a steerer and stanchions made to fit whatever clamps I can get (clamps instead of welding to the others so I can adjust ride height, etc. as needed).
Part of the reason is so I could put a powerful motor up front, without worrying about little bitty dropouts holding it in place--would be easy to have big clamping torque plates instead. The motor wouldn't have to be a hub, either, it could be a frame-mounted motor on the "triangle"; then I can have a motor *and* an IGH with a drum brake in it, for instance.
Another part of the reason is to have something that looks very different from the typical front end.
If you're curious, I have some sketches / etc. somewhere in one of the trike build or design discussion threads, probably in the old Delta Tripper thread at the end of it. I'll attach them to this post if I can find them later.
