rhitee05
LFP, you keep this sort of thing up and you'll need to start growing your beard out and dying it grey yourself...
I've read this advice elsewhere. The bead presents a high impedance and high frequencies, so it helps to damp out oscillations between the FETs.
Also, reducing the ringing that LFP referred to is a major EMI benefit. In a commercial product (that has to pass FCC testing), I would expect this to be more likely than squeezing a couple more amps out. If the designer is competent enough to put in this feature, I expect him/her to be competent enough to allow proper margin for operation as well.
whatever said:i didn't notice but there is another identical mosfet on the other side of the board in parallel, so it seems to be there to stop the ringing of the paralleled fets. Nice to know for those paralleing fets.
