macribs
- Joined
- Jul 22, 2014
- Messages
- 3,702
jakequicksilver9 said:hi Doc, don't know if you named your bike yet or not but if not may I suggest Double Treble![]()
Hmm more like double trouble
amberwolf said:jakequicksilver9 said:hi Doc, don't know if you named your bike yet or not but if not may I suggest Double Treble![]()
As long as he doesn't end up riding it off a clef....![]()
the entire power stage is different - not only the driver borards..Stielz said:Just read back through the discussion about the new 14kW Max-e. If it is in fact just the gate driver boards that have been changed I wonder if Adaptto would sell us those separately to allow us to upgrade our old version Adaptto..
cwah said:Why not using 20" for better efficiency and acceleration?
jansevr said:Doc, have you considered trying Justins statorade for increased efficiency of the hubs? Those little mxus can't be happy at 10-15kw. Even with air cooling efficiency is still low maybe 60% at 10kw. It is possible that you can increase the efficiency to 70 or even 80 at those power levels with the ferrofluid.
Awesome bike can't wait to see more progress and the unlocking of the max e!
steveo said:doc will you be posting any of your own discharge tests?
im curious to compare one of these 6s1p 4.5ah packs vs turnigy 6s1p 5ah... id like to see temps from start to finish as each ah is discharged for the cells.. maybe 50amp..75amp..100amp.. costant load would be cool to see..
how do you make these nice aluminum cases?.. im looking for a soloution to place my battery inside my new ebike..
i will look to do... 6p20s configuration with 20c turnigy lipos its will need to be 2 bricks wide by 12 bricks long per say
i need around 300amp peak... to feed that hubmonster hubie
kfong said:Haven't been on the forum for a while. Good to see you are still pushing the boundries of ebikes Doc.
madin88 said:thank you for making this very informative video. this helps a lot to understand how the Adaptto controllers work and why everyone has different maximum batt amp settings (and also max phase amps i believe).
On one of my Max-E i only can set 123A batt and 335A phase, while on another i have 138 and 370 or something like this..
@madin88: the video from DrBass is really nice. After this video and some more interesting infos from Allex and Andew/Adaptto, I change my mind and sold the "too" expensive controller. Much too many bugs, software and hardware is not worth +1000Euro ( have buy a early controller from Allex, the first and last buy from Allex, many thanks for your helping hand Allex!) My way was in the past: Lyen 9Fet, Lyen 12Fet, Lyen 12Fet-4115, Lyen 18Fet, Lyen 18Fet modding, max-e, Lyen 18Fet extrem-modding, more is waiting....
@Doctorbass: So some experience is into my lab, but looking now for my modding 4503 WC, for a better controller! Need helping hand, is the Sevcon Gen4 a good controller?
My favourite batteries are Sony VTC5 have some 12S8P, so I can connect 24S16P or 24S32P
Batteries are not my problem, Motor are also not my problem, the water-cooled 4503 is great
Yes there had been bugs, but most of them are fixed, or at least i don't have any i get annoyed of since latest Firmware.ecross said:@madin88: the video from DrBass is really nice. After this video and some more interesting infos from Allex and Andew/Adaptto, I change my mind and sold the "too" expensive controller. Much too many bugs, software and hardware is not worth +1000Euro ( have buy a early controller from Allex, the first and last buy from Allex, many thanks for your helping hand Allex!) My way was in the past: Lyen 9Fet, Lyen 12Fet, Lyen 12Fet-4115, Lyen 18Fet, Lyen 18Fet modding, max-e, Lyen 18Fet extrem-modding, more is waiting....
Ohbse said:What's happening with this bike?
Summer's here! (well, for you it is) Have you been for a ride?
