I have this thing, what I think is called a "shaft collar?", that's attached to the motor and I need to remove it. Does anyone know how? It doesn't seem to have any obvious screws to unscrew nor does it appear welded.
Very nice! I'm willing to bet that might have been the intention of the screws, even though the depth of the screws suggests multiple rods/rod-like entities(socket) that went against the shaft would be used during the course of pulling it. I'll see if I can do it. The unknown part is if I can drill the exiting metal I have laying around for the bar.TylerDurden said:Ghetto puller:
metal bar or angle-steel, bolts and a socket that fits into the hole.
tighten the bolts to push the socket (purple) down onto the shaft (green)
If the collar is not threaded for the bolts, use nuts under the collar.
Tighten the bolts evenly, a bit at a time.
