John Bozi said:surely 3 x 3 combinations don't take 3 hours? but if you've got some special plug combination........![]()
I like to see a man of serious commitment, working hard through the night.... go go go ride the dam thing before work.
Nelsjourney said:Can you post a pic of where you decided to put your breaker? I am thinking along the same lines and need ideas.
John Bozi said:Man you have to be happy with the power usage and heat seen in that video right?
John Bozi said:Your pulling almost nothing always under 2kw and under 50 degrees hold on was that celcius?
John Bozi said:If you are going to only pull 20 amps I dont think your controller will heat up or your motor ever to critical. Your range must be huge like this.
John Bozi said:Next would be nice to see some take off vids. From zero to full speed full throttle from start. And if you think you would like more acceleration speed.
I'm not sure any hub motor can handle your terrainJohn Bozi said:As usual your terrain is flat so hard to see how this motor would go for me... but it looks pretty dam promising.
Thanks John. I'm going to get my AFT back up after fixing this bike up some more. I do miss it. That bike was very light compared to this one. Good question about power consumption. Let me think about it. Lot of variables involved.John Bozi said:Ah you must be ebike heaven right now - well done and enjoy your toy..... your AFT must be having a cry right now. Are these power consumption figures better on the hub than the mid drive? since you've upped voltage.....
