TRS300
⚡ Regular
Hi all, As the title says I'm trying to get information on what exactly is shared between master and slave vesc connected by can bus. I know the slave will follow the load of the master but I'm not sure how it's doing it. Here's some scenerios...
1.) master and slave each run own motor. Both motors have temp sensors. If slave motor gets hot will the master know this and back down load to manage it?
2.) same question as above but in this case they run on separate battery trains. If slave voltage gets low will master respond to the condition
3.) throttle sets masters load delivery, is slaves duty just based on masters throttle, or does slave try to match load parameters, amps, rpm... or is it just responding to masters throttle position data?
Looked but cannot find anything on this subject. Thank you.
