NorCalTuna
1 W
- Joined
- Mar 24, 2010
- Messages
- 58
FWIW, the SCCA and many other sanctioning bodies describe weight specs, generally, "w/" driver, and they are minimums. I'm letting the worms out here a bit, but I think it's important to at least pay lip service to what has been done, historically. I agree with everything else that has been said about the rules, but dogman is right on. It's like having import drag without civics. It's like a BLT without bacon.
from an arbitrary section on shifter carts from the scca SOLO rulebook (which honestly applies as well as any other rule system here, track wise)
" Minimum weight for entrants in 125cc shifter karts is 385 lbs. as raced, including driver, regardless of driver gender or class en- tered. Weights for entrants with karts having other engines are as listed in section 19.1.D.3."
So, given a 165 lb. driver, the scca is thinking the cart should be 220 lb.
here's the whole solo book, for brain food.
http://www.scca.com/documents/Solo_Rules/2010_scca_solo_rules.pdf
honestly, a max weight contest could become dangerous and ludicrously expensive, while a min makes the sport accessible to far, far more people and setups. You want some people squeekin' by, and some people adding ballast- that way it's fair to the rider. Unfortunately, it's not really easy to safely add ballast to a bike, unless competitors know far ahead of time that they will have to.
The max weight rule is further problematic. I'll use myself as an example, at the risk of showing my hand : ^). I'm about 160 with gear and a helmet, but Nerdmobile ][ will be about 85-90 lbs- it's full sus bike, a specialized big hit fsr, an x5 and some lipo. Well, i'm SOL. NMB1 would be ok weight wise, and range and power wise, but it's not a particularly compelling tech display, and will be severely limited by it's lack of a suspension (but i'd still race it!). The rule, at 70 lbs, excludes pretty much everybody who you'd actually want to see race and pretty much every x5, which with a wheel and tire is half the weight allotment. And, by making suspension bikes basically inaccessible, the rule may even make the sport unsafe, or worse, lame. I think a good number of folks should actually weigh the bikes they have before we arbitrarily come up with that figure. Light riders like myself are naturally disinclined to this sort of rule when light vehicles are in question, which raises another reason to do a minimum: I'm sure that people who are better nourished would appreciate the lighter ones to concede a bit of the natural advantage, which is obviously part of the spirit of the SCCA rule. Honestly, I'm trying to argue for a better, more accessible and competitive event; picking a number from the hat, I say 260 lbs w/ rider min, which anybody remotely reading the last paragraph will know is entirely self serving, about my projected fighting weight, plus some ballast. 8) Hey, what can I say- this also would get the 190ish lb rider, closer to average, on that legendary 70lb bike, on the team, and make the 220 lb guy with an 80 lb rig only feel like he's at 40 lb disadvantage, rather than 90, which is me on the amazing 70 lb bike. I'm not saying it's impossible, but if your battery says "ping" or your motor says "x5" you're probably feeling the same burn right now. Even a 9C weighs 17.6 lb.
70 lbs is a very noble goal but somewhat difficult to obtain outside of very specific setups, and while it wouldn't be the first time rules write the successful equation, I'd argue that the endeavor seems to be sustainable, usable performance over absolute performance-however you bring that to the track; for that matter, accessibility and fairness over absolutes in general, which also is the ethos of AMA and SCCA racing, i'd say. Theres people who bring huge, huge dollars to those sports and you find them stuck in impound explaining away strange wires and hoses (or the aluminum "LEAD BARS" one guy had in his trans am I saw one day- how DID he think he'd get away with that?) as frequently as you find them on the podium. The really good guys are already at the BBQ.
