E-Go Cruiser Deck Mod
inb4ohnoes
10 µW
Hello, I've been a long time lurker, but recently I did something I thought was pretty neat and thought I'd share it with you peeps!
I haven't really seen a whole lot of E-Go mods on this forum, so I did my own. I like Yuneec's setup and range. It's pretty much perfect for riding around on a college campus and a bit off campus for entertainment and such :lol: but I really don't like the deck they used, which made the entire board heavier than it should have been and doesn't really add much to the aesthetics. Also the deck was too stiff to my liking, so I swapped it out.
The entire process took maybe less than an hour. Yuneec designed the board to be very modular, so really all you have to do is unscrew everything, drill 8 holes in the new deck, and screw everything back.
The replacement deck I used is the Arbor Collective Axis Bamboo http://arborcollective.com/skateboards/products/axis-bamboo/. I absolutely love the design and it's overall a very good deck. It's also flexible, which I like. You could do this with any deck that doesn't have too much of a curve though. I got the deck for $95 on Amazon Prime.
(links because images embed too large)
http://i.imgur.com/n1OY4Pj.jpg
http://i.imgur.com/NXKYhNQ.jpg
The original compared to an unmodded board:
http://i.imgur.com/QkayCaM.jpg
The original components were good enough and I didn't really have any complaints about them. A bit of tweaking a lubing straightened any issues out real quick.
Here's everything off the board. Battery pack and controller is under the new deck. The bottom compartment comes apart in two sections and you can actually disconnect the battery pack from the controller. There's a rubber layer then a foam layer that keeps the whole thing more or less watertight. The batteries on mine look to be Panasonic ones, but I didn't get enough of the rubber layer off to see more of them.
http://i.imgur.com/5TlzZKV.jpg
After drilling the holes and mounting everything back, it's pretty much finished. The whole endeavor took no more than 50ish minutes at most, and as a result the entire board is lighter and better looking than ever before!
http://i.imgur.com/YDO97hc.jpg
http://i.imgur.com/6Xs0YOL.jpg
http://i.imgur.com/RK7Ivzc.jpg
http://i.imgur.com/UaM2hjd.jpg
http://i.imgur.com/CaCAJnn.jpg
One thing to note is the issue of motor clearance between the top of the motor and the bottom of the board when you turn. Since I used a dropthrough deck, there's even less clearance between the motor and the bottom of the deck when turning. As a result I turn slightly less when I lean left than when I lean right. It's not a huge issue for me, but it might be something worth considering for some people who might want to try this using a thicker dropthrough deck.
Otherwise, everything runs fantastic! The small remote is very convenient to stash in a jacket pocket (it's about snow season over here) and the long range means I don't have to worry about charging it every day and can go pretty much everywhere I want without exerting very much effort at all. Truly the best method of transportation!
Thanks for reading!
Thanks for the comments guys!
kimoboviper I assume you mean how much the deck itself weighs. I'm actually not sure. Amazon says it weighs 5.8lbs, but if the stock Yuneec deck weights 3.7 like you said, Amazon's measurements are way off because the Arbor deck is definitely lighter than the stock.
yes i took everything off and weighed it...
a weight savings of 1lb from the stock deck would be nice. i think the 38inch loaded vanguard prolly weighs 2.7lbs.
i think i am going to put the arbor axis koa on the yuneec but I am not sure 40inches will fit in my gym locker at 24hourfitness... the stock yuneec fits great in those lockers :D .... but so far im loving this free/fun transportation :D :D
what has been your range? i am 180lbs and i can go 13.2miles with a few small hills... on completely flat grounds i bet i could get 15miles... but climbing hills really does eat the battery up
With the modded board I can go around 16-17 miles. I'm around 50 pounds lighter than you are, so that may have something to do with it. Also the ground here is really flat. It's a college campus so I find the speed perfect for maneuvering around people safely, and the new deck is definitely more agile.
the deck feels so much better but its actually 4oz heavier!! :oops: :oops: oh well... all that hard work at the gym doing work :lol: :lol:
Oh hey my friend has that deck on a regular non electric build! It's a nice deck but it definitely is heavier than the bamboo one. Nice looking build anyways though, Arbor decks always look pretty classy. What's that yellow thing on the front?
7 maple plies with a bamboo deck ply is the bamboo one
8 maple plies with the axis arbor so i doubt the weight is much different
the yellow thing is my prototype bike light holder so I can ride at night with my cygolite
i actually might go for a 33inch board later if it is atleast 1lb lighter
hmm that's true. I'm interested to see how a 33" board fares. I imagine there may be some issues with how long the battery pack is and how it might fit under the deck? I haven't investigated that much but I did a bit of quick measuring and there's not much clearance between the wheels it seems...
That bike light holder is a nice idea! Did you 3D print that?
great deck, I really like ARBOR decks; the highground is just beautiful and very similar to my WeFunk Stealth Div.
My WeFunk deck weights 1,6KG (deck only) which give me a dual diagonal motor 7S 10AH around 6KG!
no its just custom made from some metal L brackets and car duster handle i just cut... :lol: :lol: :lol: i have a real light mount coming in the mail... ill post it up when i get it.
yes arbor decks are beautiful... that's the main reason why i got it... plus it was only $85
i hope all electric boards will be modular whereby the users can swap out any components easily. doesnt matter which components from which companies....
spinningmagnets said:
Has anyone done a DIY fiberglass or carbon fiber board? CF is only expensive if someone else does it because it is time-consuming...
This is shipping soon:
https://www.kickstarter.com/projects/1664522105/marbel-the-lightest-electric-skateboard-in-the-wor
and this from an ES member:
http://endless-sphere.com/forums/viewtopic.php?f=35&t=62950&hilit=cfrp
Hey, how did you figure out where the screwheads were buried under the grip tape?
Thanks for reading!
