Rix
100 TW
That came out good Brian.
briangv99 said:Thanks Rix,
quite a compliment from the master of re-lacing wheels![]()
Rix said:briangv99 said:Thanks Rix,
Don't know about that, but your wheel looks legit![]()
Merlin said:yah its crazy loud and embarrassing :lol:
if you send me your config i can change to less noise or even no noise![]()
I did have quite a few of thosebriangv99 said:Rix said:briangv99 said:Thanks Rix,
Well yeah, was thinking about all those 18" and 19" stealth moto/hub motor wheel builds you were a pioneer of. Guess this wheel is just a bit different![]()
Cowardlyduck said:Few shots from a recent ride...
Aaaaand then this happened...
Down to my last rubber (spare) belt now...gotta get the carbon one working.
Cheers
Nah, was thankfully very close to home when it occurred and just pedalled home.briangv99 said:Did you change it out on the trail? or just click into low and pedal it home CD?
coyboyduk said:hello, problems with my 30mm motor, hall sensors broken, does anyone know where i can buy these? they can't be found at lmx anymore
TorEddy said:Maybe they are busy with this:
briangv99 said:I'm guessing maybe a planetary gearbox...
scrambler said:briangv99 said:I'm guessing maybe a planetary gearbox...
Given the lower angle of the pedaling chain, it looks like a derailleur.
But I share your wish![]()
briangv99 said:I was actually thinking planetary gearbox on the motor left hand drive side, just like your Boxxbike.
coyboyduk said:30mm vs 40mm motor? Does anyone know of a difference between a 30mm and a 40mm motor? related to the settings of the Nucular controller. poles, angle etc. because I have now replaced it, and it stutters i certain rpm?? then let the controller detect automatically, but no improvement. setting is 4pole pair and angle of 10°. or is this related to something else?
TorEddy said:Looks like its made to house a Bafang Ultra, but they chose another motor..
coyboyduk said:ok, i knew that, but is there no other difference? and are the 4 poles 10° correct? why does it stutter at certain rpm? does anyone have a solution?
