Rix
100 TW
Now this is what I am talking about, listenting to Kepler and Hyena talk tech, is like grass hopper learning something from the mighty Shaolin priest. Good stuff.
Kepler said:So this is where this experiment finishes for me. ...
My personal opinion is that its not worth the mess.
It sounds like 100ml was the sweet spot in terms of oil leaks and noise reduction. Any reason you've only gone with 50ml ?Kepler said:I will leave the motor oil lubed by adding 50ml back into the motor but I doubt if this will be enough to aid in cooling
I think Keplers main gripe was with the noise, in which case air cooling will just make it worse. But yeah, from a performance point of view I've had good results.Rix said:Hyena has also had excellent results with venting his over volted hubs which I am sure you are aware of, maybe worth trying on the bafang.
Your own theory is well established and documented :lol:I have developed my own theory why my bomber hub temp is cooler
Nice videoKepler said:I have put together a short video on replacing bearings
Heh I was thinking the same, I pulled my fighter down 2 days ago and needed a 2 foot breaker bar on the spanner to crack the freewheel loose!full-throttle said:The freewheel must've been loosened before @0:48 :lol:
Dlogic said:Replaced my bearings a week after i got my Bomber. Not because they had failed but yes, the OEM ones are ZZ types. They come with metal seals. These have a tiny gap between the inner and outer ring, as scraping metal would not be something desired. Rubber could touch though and will prevent dirt from entering. That´s why please always get the 6004 and 6005 ones with 2RS after the number. This guarantees a rubber seal. Another positive side effect is also that the grease won´t be thrown out by the centrifugal forces that occur when the bearing spins. I did use a puller though to disassemble the motor. It takes more time but prevents damage to the magnet ring. Oh and please but some grease in between the lips of the 2 rubber seals inside the plates. If not these will wear out fast or cause squeaking on the plastic piece where the wires enter.
Rix said:Set a new personal speed record on the Bomber, slight down hillgrade, WOT, pedaling my ass off in 9th. Hit 58.8 MPH or 94.6KPH.
As you can tell from my CA, I peaked at just over 71Ah with 79 volts,which comes out to just over 5.6KW. YAH!! Not fast like Hyena's Fighter or Keplers Bomber for acceleration, but pretty good.
Rick
Kepler said:Rix said:Set a new personal speed record on the Bomber, slight down hillgrade, WOT, pedaling my ass off in 9th. Hit 58.8 MPH or 94.6KPH.
Rick
That's a seriously fast Bomber you have there Rix. Also some serious stock power at 5.6kW. Looks like you got one out of the box with this bike 8)
