A few more mods to the Fighter.
Firstly, the oil is out of the motor and re packed with grease. I couldn't stop the slight weep of oil getting onto rear brake and couldn't be bothered investing any more time in this.
So to the next experiment. Pedalec. Nothing new here in general but I must admit I have read very little on the effect of Pedalec on a relatively high powered bike.
Installation was quite straight forward with the magnet ring sandwiching nicely on the Schlumpf crank. Still used the standard sensor bracket in conjunction with a spacer plate and good quality double sided tape.
Made the necessary wiring additions to the controller and added a brake switch just incase the pedalec ended up trying to throw me under a bus.
Re programmed the controller for 1000W max so nothing was going to happen to violently and set the PAS to the slow setting within the software.
So now to testing.
I have a 3 speed switch set to 30kph, 40kph, and 50kph respectively. Leaving the switch in the slowest setting, headed off for a first test. First impressions? Not to bad. Power came quite smoothly and the bike accelerated to 30kph in a nice controlled manor. Stop pedaling and the motor shut down in about 0.5 of a second.
For the motor to start, it took a full rotation of the crank to have it kick in so safety wise, it felt ok.
Next test was to bump the current limit back up to where it was at 1700W. This proved to be uncomfortably quick in its reaction and basically provided very little speed control. It was either off or up to what ever the speed limit switch was set too.
So back to around 1000W as this felt Ok as far as being usable. The pedalec does modulate throttle with cadence however, even very slow cadence will force the controller to full throttle. For this to work better, I need have the level of cadence more variable and more proportional to speed. The magnet ring I am using has 12 magnets. My thoughts are by reducing the number of magnets, I will achieve a better cadence to throttle ratio for the setup.
So plenty more experimenting required but in general, the pedalec felt quite promising and I quite liked the feeling of super legs as you pedalled along. I can see that I need to be able switch the pedalec off at handlebars for certain conditions and just use the normal throttle however I also need to get the power setting back up to 1700W and still have the Pedalec operate in a smooth controlled manor.
I have also purchased V3 Cycle Analyist for the Fighter. I got this primarily for active motor temperature management but an keen to also experiment with how the CA handles PAS.
If anyone with pedalec experience can chime in with some advice or their experiences, it would be greatly appreciated.
So why put pedalec on a Stealth Fighter? 2 reasons. The first is that I want try and comply more closely to local ebike legislation and have more chance of providing a convincing case should I get picked up on the bike. Second reason is I want to better understand pedalec characteristics for new commuter build that I have in the planing stages at the moment.
