Rix
100 TW
pendragon8000 said:thanks for explaining . just to clarify its like a bmx axle position / chain tensioner, a clamping torque arm/dropout and then the axle nut? sounds like im missing something.Allex said:Stealth has Actually tripple safeties for the axle.
First one clamps on the Axle itself,
Second, you slide the wheel with that clamp to the dropouts. Dropouts then hold the clamp and the axle in place and keeps them from rotating.
Third, you add the axle-chain-tensioners.
PenD, yes the dropout is kind of like a 10mm thick axle dropout on a BMX. but the dropout shape is kind of like and inward beveled C chanel iron in shape. For the axle nut to be secured properly the torque block needs to be in place. If thats in place and if the axle nut could handle a 150nm of torque, the thread post on the end wouldn't be needed for maintaining axle placement in the dropout. Look at my home made pinch torque arm pic, you can see what I am talking about.
Rick
