So I've been thinking about getting a new rear shock for my Fighter.
Ever since I put the 200mm DNM on the front, I keep pedal striking when cornering hard. Yeah I know there's a technique keeping the inside pedal high, and I already do that. The problems have only started since I switched to the DNM, so I can only conclude that the change in geometry is not compatible with my pedal and cornering style.
Anyway, what does everyone think of this shock for the Fighter:
http://www.cyclingdeal.com.au/buy/dnm-mountain-downhill-bike-rear-shock-220mm-or-190/BURNER-RCP2
I don't really want to spend any more than that.
What length would you recommend? I'm thinking 220mm, but it also comes in 210 and 240mm, so not sure if I should go for one of those.
I don't need much lift in the rear...probably only 15-20mm would be enough, but I'm not sure on the length of the current (original DNM RCL-8) shock. It was 165-190mm, but I don't know what Stealth put on the stock Fighters around the period I bought mine 2011-1012.
Cheers
Cheers
