Emmett said:
You guys confuse me with this controller talk. So ... If I keep my Fighter's rear hub setup, what are my best hot-up options?
If you want to keep your existing motor I would think a mini-e would be the way to go - sinewave smoothness, OVS for more speed if you want it and around 6kw peak.
... If you want more range then you need more AH from the battery. If you want more efficiency you need to keep the speed down, so using the OVS features on the controller would probably be something you'd want to avoid. If you want more range and your stock battery is tired you can get a fair bit of capacity with a replacement 18650 pack. With the new 3.5ah cells that are available now you could ride until the cows come home and still get decent performance because even with the lower C rate you've got a much bigger AH capacity to multiply out. Eg if you can fit in 30ah 3C is 90A
I reckon you could just about get away with fitting a mini along side the stock battery. I like to internal mount my controllers when ever possible but as Rod said they will get hotter with no air flow - especially the mini, which is around half the size of the stock controller. Heatsinking to the frame would be the way to go, or modding with fans, but in a stock fighter there's no room. Maybe oil filling the controller would help too!
I don't have a fighter any more but you're welcome to swing by my joint one day if you want to dummy fit some stuff. It'd be a good excuse to show you my local trails too :wink:
