DasDouble said:
Which one do you like more? And especially which one for street riding?
I guess for street I will like more the stock 5403 with a trial tyre on it.
But for the moment I do not know because what I have done so far is tried to adjust the Angle correction and Ind timing with the wheel off the ground. Being the first time I made this stuff I don't know if there are margins of improvements. I will try to ride at 15Km for some km, record the motor temp, change the Angle correction and repeat from the beginning.
Then for Ind timing I will do the same at a speed of about 50Km/h and keep going until I get the lowest possible motor temp.
Then PWR timing ....
.... yes
it's hard to be a pro
This is the very first ride I made this morning with the new QS205. I lowered the BOOST mode at 140 bat Amps and 280 phase Amps and the motor reached the temperature of 60°C doing a short WOT from about 20Km/h .... I hope to improve the situation :?
This is what the Bomber looks like with QS 205:
And this is how I managed to route the phase wires to avoid rubbing on V-boxx gear selector sheath
