Merlin said:
thx for that video....but now the question is, how much amps can i get for free?
what did i have to monitor to prevent any damage to the charger?
Take as much as you dare...
:lol:
Seriously though, it just comes down to heat mostly. Turning a lower rated charger up will make it get real hot if you push things too far. Once you can really feel the heat coming off the shell, it's time to turn it down IMO. Also keep in mind, while increasing charge rate will decrease charging time, it will also degrade your battery faster after a certain point, so it's a trade off.
Emmett said:
ITtd be great to learn what that 3rd pot is for (eg. fine tune or final charge adjustment), and which pot it is. I'll not change it, after I know which one it is.
CD, I watched your charger adjustment video on youtube. Thanks. Three questions please:
Thanks Emmett. I'll try and keep responses short as to not derail this thread from Stealth too much, although I failed to point out that this is one of my old Stealth chargers and I've been using it to charge 12S LiPo for years now without issue.
Emmett said:
1. Finding Amps pot: I presume the AC input Watts stays constant if you adjust the ouput volts POT because the output Amps will auto adjust to keep the same Watts. On the otherhand, amps adjust must change in the input Watts - correct?
Yeah, from what I've seen, adjusting volts on these and similar chargers does not change overall watts, and adjusting amps does, so you presume correct.
Emmett said:
2. Adjusting volts pot: Both my Li-Ion chargers output no volts when I disconnect the battery. So I guess the DC-1 display and controller do not draw enough current to make my chargers go live on their output. So I'm still unsure of the best process to adjust my voltage pot. I guess I must use a volt meterwhile it's charging. Correct?
That's interesting. Something else could be up there as the charger typically needs to keep things flowing to allow the BMS to do it's job of balancing the pack which doesn't draw much current at all. Using a multimeter while charging isn't going to help much with adjusting volts as the charger automatically matches it's volts to the battery level while charging. You'll have to figure out a way to get the charger to come 'live' and adjust the volts from there. One option might be to disconnect the battery, but not the charger and turn the throttle to draw power directly from the charger. The harness I made you would allow you to do that without having a battery connected.
Emmett said:
3. My wall socket power meter displays a "Power factor". Says 55% 241V 2.5A and 331W when powering my Stealth charger. 241 * 2.5 *0.55 = 331W. So (reading this https://en.wikipedia.org/wiki/Power_factor) my meter shows real Watts and the apparent Amps. Seems odd mine shows apparent amps. How does yours work?
Not sure how mine works TBH...it's just from Aldi. :lol: But real watts sounds like the thing we want for this job.
Theodore Voltaire said:
I thought the bms is what turns off the charger when the battery current gets close to zero.
This is the opposite behaviour to what I've seen/understand...at least from the earlier Stealth models. On mine the BMS uses the charger to pulse charge lower cells. You can hear this as the charger clicks on/off when the BMS is balancing.
What I've noticed about charging is at first the voltage is low, and the current his high. As the battery charges the voltage rises, and the current gets less, and less until it's almost zero, and then the charger shuts off.
Yes, but it's not linear like that. Most chargers will keep a constant current flowing until they approach the last 10-15% of the charge state, then taper off from there. So as long as you adjust the amps before that taper point, you are ok.
On a lot of these chargers I believe the 3rd pot can also adjust this taper point to come in sooner or later.
Hope that helps everyone.
Cheers
