Rix said:
John, think this would work for our ebikes? https://www.circuitspecialists.com/csi10015.html
I dont think it is suitable because it doesn't have current adjustment or coarse/fine adjustment on voltage.
Thats why checked before pulling the trigger. Thanks Kep.
Given the cost of the programmable dc dc converters I posted I'm at a loss as to why anyone would opt for a satiator at almost ten times the price.
They are a great option Sam and i have ordered one today to play with. You still need a power supply though and one with a bit of grunt if you want to charge at a high rate.
The big advantage of a using a PSU for the power supply is the ability to test anything. I like being able to charge just a single cell or multiple cells plus having the ability to test things like hall sensors, low voltage cut offs and various other low voltage circuits. Unfortunately you don't have this sort of flexibility with a DC-DC.
I think the big arse 100V 15A PSU still has merit especially if you are looking to charge big packs at a decent rate.
All well and good if you find a grunty power supply from and old PC but a power supply like a 320W 24V Meanwell is still going to cost you as much as PSU as far as i can see.
Yeah I have to confess I have a bunch of old power supplies. In fact as well as old pcs I have a drawer full of old 90w laptop psus etc.
The floating input voltage feature is pretty cool. Not much of a day for solar.
Bummer tipped over my bike broke rear brake lever. Found set Shimano XTR good price should I buy would they fit on our bikes? Should I stick with new set of MT 6
Sold
Fore Sale
Gator 8 Pot Brakes. Perfect for your Stealth Bomber or Fighter. Complete set of brakes with 2 setts off rotors (one set in Gold color and one set in Silver) Silver brake rotors are brand new never used. 2 brake handles and 2 packs of brand new brake pads. And a complete sett off slightly used brake pads. All bolts and adapters are included. Rear brake needs Oil and a re bleed. Serious Offers accepted. See pictures for info.
I just destroyed a new Honda Grom in a drag race. Before the light turned he ask me how fast my bike is. I told him not that fast, and he started smiling. Then I told him it struggles to do 50, and he stopped smiling. :)
Thats so classic.
one4torque said:
I'm a fan of those gatorbrakes....... some people complain about them, but I like the modulation/feel on my old sb 178.
LMK what you are asking... although shipping from norway to TEXAS might be a problem?
PM Sent :)
Bomber 350 is under the knife…. frame up rebuild in progress and will be updating this week….
Searching for new brakes for my bomber.. we ride Moto Style left hand rear brake right hand front brake.. what are cable length suggestions for European websites to order anything I see from USA websites is set up for left hand front brake thanks confused butt learning
My Bomber came from the factory with RH front brake
1000mm front, 1700mm rear you can swap the hand controls your prob going to have to cut the rear line anyway because it will be too long..you can swap and cut lines w/o rebeeding if you are careful.
Im interested in those brakes. Please send me a PM with prices plus shipping to germany.
stritzky said:
Ok Whats wrong with it ? Cracked frame.
Ill post up pics once all done but a bunch o little stuff that was bugging me. ex I welded all of the nuts for the side covers on the frame because they were all getting loose. Reinforced the corners of the frame where the side covers mount by the back top and bottom corners, new electrical connectors, rebuild / resealed motor, new paint…added thermistor...basically everything that was bugging me from factory stealth was removed and replaced or rebuilt.
All US destined Bombers, Fighters and Hurricanes do.
1ab - I did the same thing to my SB178 I bought used with uh-hem....."only 200 miles" on it! LMAO!
A bunch of little stuff was piling up.... cracked seat frame, bent cranks, bad v-boxx, ca button failed, rust inside lower part of frame batt compartment, bent key (almost broke off), bald tires, worn out rear chain freewheel, brake pads used up, bent seat, cracked throttle actuator....... you get the drift........ it was pretty damn fun to rebuild from top to bottom, new paint, then re-build with all new parts, refurbed parts...... like building a master-pc.
GL Enjoy and pleeeezz post up sb pron!
That is a beautiful riding area there Allex.
Speaking of, I'm not sure if it's your picture or something else but I'm feeling pretty Scandinavian today!
