Cozen89 said:
Could use some expert advice on connecting a headlight directly to my F37 battery. I plan on using a Fisher Fabhouse led headlight that works from 36-96V to avoid the need for a dc converter. The light connects via a XT30.
I was able to find some Y connectors and connect the light to my battery via the cable that plugs in to the charging port. Do any of you see a problem with this rather than tapping in to the discharge cable off the battery? Possible a bms issue or anything like that?
I’m trying to avoid splicing and soldering as I haven’t done that before. What do y’all think? Here’s a picture of the light below. Thanks!
My knee jerk reaction is not to power anything off of the charge port, but considering on my bike it's already subjected to up to 6 amps from the charger, I can't really think of a good reason not to. I installed a 1 amp fuse on my lighting circuit just in case.
