Billy.A said:
That's a real bummer Billy. Pushing a Bomber with a flat tire for miles is no walk in the park. Something must be different between your new bike and mine. When my bike was brand new I removed the stock razorback, and installed street tires. I remember it was a very hard tire to get off the rim. On your bike they just hop off.
yes Theodore, they are definitely a soft tyre. Im guessing there is a defect in the bead, 2 in one Month is not right!
1abv said:
After many different attempts to modify the tire/ rim combo I switched to moto. Now when I get a flat I can ride it out of anything.
Perfecto!!
1abv said:
I noticed a very very slight difference in handling when I went to moto but well worth it. I use regular moto tubes. I never went w HD moto tubes. Maybe some other peeps here did?
Im willing to sacrifice a little bit of handling plus some extra weight to achieve confidence and piece of mind.
plus my bike was fitted factory with a rear rim on the front which is bigger and thicker so the front wheel is an upgrade in itself.
1abv said:
Im sure you cleaned everything before installing the new tire/ tube combo and the pressure was normal.. So the only things I can think of are:
After the first blow out ,i took the bike to Stealth HQ ( i live less than 10 mins away from where they make these machines and the inspection and new rear tyre was fitted by Stealth themselves.
1abv said:
Do any of the spoke heads poke through the rim possibly puncturing the tube?
Is there a crack or deformation on the rim?
No, the spokes and rim tape are good. The bead jumped the rim first, then the tube popped after i got off the bike to release some pressure, its a tyre issue..
1abv said:
Either way I would go moto. I feel that the bikes should come standard w at least a rear moto rim if not both front and rear. Tires last wayyyyyy longer like years vs months and the weight difference is well worth it and you can run lower pressures. The tire selection is greater as well.
Yes, agreed mate. Im not lifting the bike too often so the extra couple of kg shouldn't be an issue i would think.
Thank you everyone for your your sympathetic ears and advice,
Man this bike is constantly evolving!
ive asked the boys at Stealth to sit a black rear rim on my bike and take a photo, want to see how she looks with one red rim and one black rim, if it looks shit, they will send the rim out to be powder coated red..
Have a great day/evening everyone
