Last night I went on a second range test. The main difference this time was I used a lot less full throttle, but the average speed was about the same, 20.4 vs 20.8. This time I rode 40.8 miles, avg sp 20.4, top speed 47.8, and at the end of the ride voltage was 71.4 v. Even though I didn't use full throttle as much I was riding, and accelerating almost the same as the first test. Charge time was 3.5 hours.
I ridden this same route many times, and typically I use about 21 ah. With my charger still set on 6 amp, 3.5 x 6 is oh guess what? 21 ah. That works out to 40.8 divided by 21 = 1.94 miles per volt. Slightly better than the first test by not using full throttle. Otherwise there wasn't much difference in the actual riding experience. That works out to about 58 mile range.
My conclusion is I'm pretty confidant in saying, I can ride a little more aggressively just cruising around than before, and still have slightly more range as long as I stay off full throttle. The difference is not gigantic, but it is noticable. That makes the low speed button even more attractive.
So the bottom line as far as range goes, is it hasn't changed much. I still have way more range than I typically need no matter how I ride, but now I could probably extend it a little more than before by riding slow.
