Bullfrog said:Rix said:Bullfrog said:What motor comes in the Stealth B-52 at this point?
If it is not the Crystalyte motor with a 55mm tall stator, has anyone used the H5580 or H55100 motor? It appears it comes in a couple different widths one of which will fit a bike with 135mm dropouts.
Thanks
Stealth is currently using the H55xx UFO series. Minus the different hub side covers and spoke flange drillings, its the same is the standard H55xx series. I don't think an H55 will fit a 135mm dropout, if it does, there won't be enough room for the disk brake and freewheel, You may want to look at the H40xx or H35xx series. Those will fit and you can probably fit up to a 5 or 6 speed free wheel.
Thank You .
I'll check with Crystalyte on the disc brake rotor/freewheel. Sent them a message a while back and the actual width of the H55xx motor is 140mm so it should fit in a steel framed 135mm bike with a little flexing.
Rix said:Bullfrog said:Rix said:Bullfrog said:What motor comes in the Stealth B-52 at this point?
Thanks
Thank You .
Was it the axle face width they referenced as 140mm?
Okay thats good, the 140mm is the axle width, don't expect much room for anything but a single speed free wheel.Bullfrog said:Rix said:Bullfrog said:Rix said:Stealth is currently using the H55xx UFO series. Minus the different hub side covers and spoke flange drillings, its the same is the standard H55xx series. I don't think an H55 will fit a 135mm dropout, if it does, there won't be enough room for the disk brake and freewheel, You may want to look at the H40xx or H35xx series. Those will fit and you can probably fit up to a 5 or 6 speed free wheel.
Thank You .
The Crystalyte web site and the guy I was corresponding with said the H55xx motor was available in three widths: 140mm / 162mm / 190mm.
TV would disagree, but the Bomber is in its natural environment.1abv said:131E5C74-BA6E-4CBD-8CDA-0AC4CA592C6B.jpeg
Bomber don’t care about trees…
Rix said:TV would disagree, but the Bomber is in its natural environment.1abv said:131E5C74-BA6E-4CBD-8CDA-0AC4CA592C6B.jpeg
:lol:Theodore Voltaire said:Rix said:TV would disagree, but the Bomber is in its natural environment.1abv said:131E5C74-BA6E-4CBD-8CDA-0AC4CA592C6B.jpeg
I always say you can ride any motorbike anywhere, they used to ride Harley big twins in the dirt. Some bikes are just better at it than others.
Theodore Voltaire said:"We want to be free, free to do what we want to do. We want to be free to ride. We want to be free to ride our machines, and not be hassled by the man, and we want to get loaded, and we want to have a good time, and that's what we're gona to do, we're gona have a party."
Rix said:Theodore Voltaire said:"We want to be free, free to do what we want to do. We want to be free to ride. We want to be free to ride our machines, and not be hassled by the man, and we want to get loaded, and we want to have a good time, and that's what we're gona to do, we're gona have a party."
Peter Fonda, Easy Rider?
Good mods there, Jealous you got to test ride directly from the skunk works. Thats awesome.TimL said:A while ago i showed progress pics of my quest to reduce the maintenance on my B52. I'd like a belt drive, but it sounds like its too difficult. In the meantime, my chain is now enclosed most of the way around which has made a massive difference to wear, lubrication and adjustment intervals.
I'm a bit slack and STILL haven't enclosed the rear bit at the motor, even though i have some material to try it with.
The front section is welded onto the stock cover and been given a quick lick of paint.
Was a bit of a challenge getting it to clear the crank and chain, but it works a treat.
Obviously i need to remove the whole cover to replace the chain, but now that the chain lasts 20x longer its not a hassle at all.
This bike is (more or less) a "daily driver" 22km each way to work and i forgot how much i appreciate the performance until i rode a "regular" ebike to work one day and was struggling to do 20km/hr into a headwind that the B52 would have laughed at.
Theodore Voltaire said:I worked on this all day, but this makes up for it.
Theodore Voltaire said:At long last, a seat big enough for my big ass
