LI-ghtcycle
Well, I thought I should start another build thread since the heart and soul of my touring bike will be significantly different than anything I have built previously, and there are two major things about this build.
Priority 1) Build it strong, simple and reliable -
I have been looking into internal-geared hubs such as Sturmy-Archer, SRAM/Sachs and Shimano. For the money, I wasn't terribly impressed with any of these brands, and was concerned about their inner workings and complexity, and was lead to the Nuvinci, particularly the original 350% model that seems to have a very strong track record (yes I know it's only 4 years old, but I know of a shop that hasn't had any returned or needing service in that time either) for both reliability and a wide gear ratio. And for the money I can get a wheel built with a Nuvinci 350 (extra heavy duty cargo bike wheel) and a wider gear ratio than a comparable hub in one of the other companies, and then I have to pay for it to be laced into a wheel. I was at the LBS the other day when a guy on a recumbent came in because the small shifting chain on his Sturmy-Archer had broken, and I wonder how many LBS's around the country would carry anything like that. Granted any failure of the Nuvinci would be much more difficult to repair, and would not likely be supported just about anywhere, but my understanding is they have very little to break, and short of a nasty accident where the Nuvinci hub it's self is broken, they are pretty bomb proof.
Priority 2) Build it from components that can be serviced at most bike shops anytown USA -
I am looking into having either double butted 14G spokes or go with 13G as used by one company (14G are going to be much more available) for a wheel built just for this purpose, I will either buy a pre-built wheel or have a local shop lace up about as strong a wheel as I can get and stay in the 14 - 13G range of spokes.
I am also going to use a single speed freewheel on the Nuvinci, 16T most likely and have a granny ring (probably 20-30 tooth) that will be only for serious hills and or E-Drive brakedowns and a more large (38 - 44 tooth) main sprocket that I would be using the gearing to pedal with the motor 99% of the time anyway. I'm hoping I can use a standard derailer as a tensioner, if not I will get a DH or BMX chain tensioner.
This will NOT be a case where the Nuvinci is part of the electric drive-train. It will be used strictly for pedaling, and the wheel will be turned with a HK 130kV Turnigy motor running at 8 - 10S (testing at 8S first) via belt drive as the build is done in grinhill's MKII build.
Priority 3) Keep the rider and the cargo dry (mostly the cargo, as it's not a recumbent, full coverage fairing isn't practical) -
My first attempt at an enclosed covered cargo touring bike isn't a failure, but needs to address 2 major flaws:
1) Lack of balance! (WAAAAAAAAAYYYYY too back heavy)
2) Lack of maneuverability (Not allowing for normal movement of the bike, i.e. rear wheel not exposed enough to lift and pivot bike from rear wheel)
Ok, so how maneuverable is a 150 lb bike filled with camping/touring gear for a trip across the USA going to be anyway!? It's going to be much more difficult to maneuver than anything that is normal weight, but it should be no less maneuverable than any other touring bike carrying the same weight in touring gear. So far I have succeeded in keeping the back cargo area dry, the front needed a little more sealing, but nothing terrible.
I will be addressing the weight balance issue by using the biggest low riding front panniers I can comfortably fit, and try to keep the denser gear up there and put the bulkier stuff in the back.
So far for this project I have a Silver Tidal Force Frame, Surley Big Dummy Forks, Crow Cycle center stand (the beefiest one with all steel except the aluminum adjustable legs at the bottom) and my next acquisition will be the Nuvinci (hopefully at a discount rate since there is the new 360 to bring it's price down) hub.
I will add some pics later tonight, but right now after taking care of other errands all day, I'm gonna go put my beast together with what I have nearby and ride it!
I'm also trying to think of a fun name to give it, and would love to hear you suggestions!
So far just brainstorming, I have come up with:
Big-E-Bike (as in Biggie-Bike)
Flying-E-Brick
Bike-E-Baggo (like Winnebaggo )
E-Trekker
E-Traveler
Ebike -Trucker
Sur-E-Bike
Help me come up with a better name! :lol:
Flying-E-Brick
E-Trekker
E-Traveler
Ebike -Trucker
Sur-E-Bike
