I have no balancing so no "artificial" heat. I placed the temp sensor and it's ground connection by the negative pad of the board. That pad will connect to the Cell- through a very short and large conductor for good heat transfer.
At around 40mA per pin port and 200mA per port and chip you (didn't check the exact values on these AVR versions), that's a maximum of 5 pins you can use at max dissipation. If you have extra pins, you can distribute the load using more pins at lower current, so that less heat is dissipated at the chip and more on the external resistors. Nevertheless, the heat is going up.
In a cheaper version of the monitor it maybe good enough to use a roughly calibrated temp sensor on the AVR. Instead of having an exact temp monitoring, you would have a rough value just to use as an alarm. However, when balancing, readings are probably screwed anyways, and I would want to monitor cell temp closely during charge.
