A lot will depend on how you ride it. Lowering the wattage should mean a slower top speed, and that will ALLWAYS mean better range than using the motor to go faster. It's too easy to let the throttle creep up, and go faster, blowing your battery. Lots of kits now have several power levels to choose from on the display, the lower level always ends up taking you farther, even with PAS instead of throttle.
I've done a lot of rides where getting your range matters just a bit. The next town, or even a house, 70 miles away, burning desert, and a mountain along the way. you gotta make it.
The best range is again, slow down. Ride the speed you normally would ride. I'm assuming this pedal cruise will be perhaps 15-18 mph, without a peloton to suck you along. Select the right gear for a comfortable cadence, maybe not the highest if it's a road bike. Then bring up the throttle just enough to make the pedaling easier, yet still pedal hard enough to bring up your heart rate significantly. Same feel you get with a light tailwind. Not flying, but easier.
This should put your wattage draw in the 200w ballpark, allowing a two hour ride from a 400 watt hour battery, or more. Off the throttle completely when possible, all the downhill, or if you do get that nice tailwind.
The most extreme range extender is false range. You see this claimed by retailers all the time. Who cares how far you can go with the motor off, or running at a meaningless 50w. ( 50w is only enough to cancel out the battery and motor weight) But if you use that motor only when on a hill or headwind, then your range is essentially infinite. But when its off, you have to pedal up that extra 50w, just like carrying 20 pounds of beer in a pannier feels.
The best range will be pulling an average of 100w continuous, including any motor off time. If you can get by on 100w average, then a small 400 wh battery will go 4 hours, 60 miles at 15 mph. It's not much assist, but having 250w for a few min up the hills will still be priceless.
To really get the max range, riding with a cycleanalyst is the way to go. On those desert rides, I know I will make it if I can hit 25 watt hours per mile for my average . The CA gives me a running average, so if I see it higher than 25 wh/mi halfway, I need to slow down till I get a lower average. Or,, if it's showing 20 wh/mi, I know I can take the last half faster. Priceless info.
