Ebikebert
hello guys I am at the point of giving up!! I have a big problem! My bikes specs are as follows modified 1000W yescomusa motor, 9 fet 40A lyen controller, 20s 4p Samsung 25R battery pack. With this setup I figured i would hit 40 mph without any problem for sure. Well i was wrong. My problems started when I attempted to hit 40 for the first time and maxed out at only 30 mph. I knew this to be off either in the motor or controller side because I knew that the battery could deliver more than i wanted (more than 6500W). However I noticed that the motor was running a bit more rough than usual and was also quite noisier at the same time. So I thought it might be the motor. I then went inside and attempted to mess with the throttle voltage and attempted to supply 5v to the throttle wire on the controller which in turn blew up a few mosfets. With the controller broken i sent it back to lyen for repair. %0 some dollars later and After a few months of waitng i get it back with 40A programed as the max discharge instead of 30A. The controller came with a new problem however when i hooked up the cycle analyst to the controller it reads a completely wrong voltage that fluctuates as the wheel turns!! I figured that the CA feature was just broken because the controller works fine otherwise. And lyen sent me this video showing that it functioned.
https://www.youtube.com/watch?v=ksCt3j8uQ1U&feature=youtu.be
note that my motor does not sound nearly as smooth as this motor does which hints to the fact that the problem lies in the motor i believe. Today i went out for a top speed run can you guess what it was? 21 mph!!!! 19 mph slower than where it should be with my controller and battery setup. Note that i have modified the motor with vent holes, input larger phase wires, and temp moniter. After around 3 min of riding my motor was at 100 degrees celsius or 212 farenheit. So i am thinking there is some sort of short in my motor or something because of the rapid increase in temperature. Also a small side note when applying throttle to the motor only the first 1/3 of the throttle responds to any speed change after that there is nothing more the throttle is able to give. I believe that the controller is doing its job of supplying 40A because how else would the motor have heated up so quickly with vent holes!!! Thankyou for hearing my story i hope you guys can help me fix my cycle analyst and believed to be motor problem. Thank you so much for reading this hope you gguys can help me in my dark hour.
