A friend of mine has a cable lock with an alarm built into it so if they cut the cable it goes off! Not sure if it is motion sensored as well.biohazardman said:Lets not forget what they often use to cut metals in a hurry. It's the tool you see them cutting some of the Britt's guns up with some years back. Just a simple cutoff wheel and these fine workhorse tools are available for the cordless Dremel tools these days. Only takes a couple of minutes to cut most any lock or chain hardened or not. I have cut several locks with them thus far. Cable cuts in a few seconds with a good cable cutter or sharp bolt cutters. Although the good cable stuff in earlier pics is as good as it gets it's still not much good. I use them anyway and keep my bike where I can see it near a busy door.
Locks are to keep honest people honest and stupid thieves at bay. They mean little to the professional.
HAL9000v2.0 said:Just finish this few days ago...
I put RFID tag inside simple car remote door opening transmitter. Now I have remote On/off and when transmitter is more than 1,5m from bike; the power is off and all three motor fazes connects together so the wheel is virtually blocked. But the best feature is range of some 50m so you can lend someone the bike and shut it off when he leaves.
