Ebmx melting throttle button
skuzzlebut
Canada
Just made a sick electric bmx. 12v 250w gear reduction chain drive motor, running on 20v drill batterys. More than enough for some added fun at the skatepark at gets me about 20-30kmph on flat ground. Throttle applied while pedaling makes short work of hills. I'm trying to run it without a controller to save on space and cost. I keep melting the intermittent buttons I'm using as throttle, they are all I need but need something more hd for when i run the motor for long periods uphill. Variable speed would be nice if possible on a intermitent button. I'm using a 12/24v 20amp heavy duty button from Amazon. I saw they do make a 50 amp but the issue with the last 20amp one was the plastic housing around the contacts melted to the point they separated internally and I doubt a 50 amp button would fix that issue. Any advice?
You'll need to use a button that could be as large as or larger than, and more expensive than, a simple cheap brushed controller from some place like electricscooterparts.com.
First, the button must be rated for continuous current at the current your system *actually draws*, whatever that is (which could be a hundred amps or more depending on the load placed on the motor).
Second, it must be able to handle the arcing that happens at connect and disconnect each time, without welding it's contacts or burning them. (this is less of an issue at lower voltages but it still occurs, and at high currents it is a seriously damaging problem).
You'd have to measure the actual current your system draw under the worst case load to see how many amps your switch has to be rated for, by placing an ammeter or wattmeter in series with one of the battery-to-motor wires and going for a ride while watching the meter to see what the highest load is. A slow-reacting meter will not be accurate for readings shorter than it's display refresh time (some take several seconds to react) and you could have much higher current than what it shows, if the loads aren't continuously high long enough to read it.
I went thru all this with my first experiments on DayGlo Avenger; there's a thread on here that starts after that point; earlier stuff is still up on my old The Electricle™ : Bicycle Electric-Motor-Assist Project page, assuming google left those intact in the years since then. I pretty quickly went to using a controller instead, and have kept going up from there the last decade and a half or more. ;)
If you want variable speed, you'll need a controller appropriate for the voltage range of the batteries you're using (check their charger for the full-charge voltage it puts out, and the manual or labelling for the LVC or "empty" voltage to not use them below); and the appropriate type of throttle for that specific controller.
For a 20v battery, this range would probably work
and these are the various kinds of throttles; you'd need to get one that matches the controller you pick.
To get variable speed without a controller requires a huge varistor or wirewound pot, etc., whcih you can get in stage lighting controls. Look around the forum or that blog for my pics of a gigantic Luxtrol control I came across that is bigger as a 500-1000w hubmotor, and weighs more. (presently I'm using a pair of tiny brushless controllers that each fit in the palm of your hand to run a pair of hubmotors at around 2000w each for a few seconds to start up the heavy-heavy-cargo SB Cruiser trike...technology can be amazing).
Wow thanks so much for all the info! I guess I'll be trying to get my hands on a small controller I can fit in the carrying bag. I tried a couple cheap pos ones already and they burnt out within a day but I'm sure I just need something quality. If I get a larger say 36v controller with the possible later addition of a 36v battery would that cause issues with the current 20v setup? I think the motor will handle being over volted it's got some beefy leads and windings from what I can tell there is no difference to the 24v model.
Sounds like you have quite the build! Unfortunately pics are no longer viewable. I'd love to get to the 2000w point lol. My whole setup is under 100$ canadian considering I had the drill batterys already.
Also I'm no electrician but if i were to get the 18v controller is it limited to the 250w? If I'm running a 12v motor at 18v won't the wattage go up too?
The voltage of the controller refers to a few things:
--LVC, the point at which it stops trying to operate the motor, so that it can protect your batteries from you overdischarging them (which can damage them in ways that can lead to a fire). Most of the tool batteries I've seen don't have internal BMS to do this; they rely on the tool to stop, or the user to pay attention to tool behavior or a little meter light or whatever. So a higher voltage controller may not even run at all on a lower voltage battery.
--Voltage limits of parts inside the controller. Higher voltage units will have parts that can handle the higher voltages, while lower voltage ones might blow up if used at higher voltages than they were designed for.
--Controllers capable of regen may also have an HVC that prevents regen above some voltage to prevent battery or controller damage.
Voltages listed on all of these controllers, batteries***, etc are "nominal", meaning the voltage the batteries would be at half-charge. There's a lot of threads discussing various kinds of batteries and cells and their various voltages, etc., if you want to dive off the deep end.
***tool batteries may actually list the *full* voltage just so they sound better than they actually are.
I started out doing everything entirely with parts I already had, or could get free as discards from other people. I still do that as much as possible, as I still don't have much more money than I did then (maybe not any more, given all the recent inflation).
Plus...it's fun to see what I can misuse for my purposes that it was never intended to do****...I just now have some experience in what has a *chance* of working, which I didn't at the time. :oops:
****I do that with my music and other stuff as well, like the most recent song Behind You Lie Many Unseen, by Amberwolf that uses some spoken elven intended for quiet "cinematic" music and some chants to make vocals for "rock" and "funk" sections at the end of the song.
If you're running a 12v motor at 20v+ (whatever actual voltage those packs are at) with no current limiting (no controller to do PWM) you're already running it at much more than it's design wattage. ;) Sometimes that's ok, and sometimes it can damage the motor by overheating the windings or the magnets.
Also, running a brushed motor faster than it's design speed by enough RPM could cause the commutator segments to come loose, which will destroy the motor; you're unlikely to have this issue at your voltage, but go up to a few to several times it's orignal RPM or more and it might begin to be a concern. The smaller diameter the motor/comm is the less likely this is to be a problem, but get up into bigger forklift motors and it can be.
Some thoughts:
How hot does the motor get? The battery? What voltage does the battery drop to under load, from what voltage without the load, under various conditions (and what are the conditions)?
Just at a guess, if you had maybe a 5% slope (pretty shallow), you could be pulling 500 to 1000 watts out of the battery, with most of that turning into heat inside the motor. (also depends on the gearing ratio between motor and wheel, and hte wheel size, and the RPM the motor was designed to spin at).
There are calculators to figure out the required power to move at a certain speed with a certain weight up a certain slope (or just on the flats against wind resistance), that can guesstimate the power being used in total, for a given set of riding conditions; that's the power the the motor would have to provide in order to do that job. It would actually be getting *more* than that power from the battery, and the difference ends up as heat. (how much more, you'd have to be measuring under those condtiions).
I completely burned up the windings on my first little "unite" motor trying to chain drive the rear wheel with no controller.
Holy crap you think I could be pulling that much wattage from the battery??ok I understand a 36v controller might register a dead battery and not function on 20v. So basicly if I have a 18v 250w controller it will limit me at that low of a voltage and I won't have the power I'm experiencing now if im pulling 500w uphill? Ill do some testing to see what kind of voltage and amprage im getting, i need to buy a new multi meter anyway. Then I'll get a 18v controller rated for whatever wattage I max out at (if they make one). Your right the batterys don't have a built in bms, only in the tools. I just keep an eye on the discharge. they are around 18v under load and I think 19.2ish fully charged though advertised as 20. I changed the gearing on the motor from a 9 tooth to a 13 and the back is a 18 tooth freewheel I believe. The 9 tooth was too slow and i diddnt need more torque. 20 inch bmx wheels. The thing rips me along surprisingly well at 190lbs and I get about an hour of ride time out of a 4 ah drill battery. (9 ah on the way 🤤) battery and motor seem to stay very cool warm at best. Just the terminals of the intermittent button get super hot. I was running it by just directly connecting the motor leads to the battery and everything worked great, was just super janky to ride. Either ripping full speed without stop or off and hard to work the terminals while riding.
thanks for sharing your experiences, sounds a lot like myself. Im new to ebikes but been riding motor and pedal bikes all my life.
19.6v full charge no load
13v at lowest with a heavy load uphill without pedaling or at take off.
15-16v normally riding.
Hard to measure amps I couldn't find one that measured over 10amps and I think I popped the fuse at 10.
If it's 19.6v full, then assuming typical 4.1-4.2v-full cell chemistry, it's a 5s pack, or 5 cells in series. 13v / 5 = 2.6v each cell, which is below safe operating minimum voltage and can damage the cells. 15v / 5 = 3v each cell, which is below where a typical controller would shut off (3.1-3.3v / cell) to minimize stress on the cells.
If the cells were charged up to 19.6 / 5 = 3.92v, then under an acceptable load (for that cell model / battery configuration) they shouldn't sag down to more than 3.7-3.8v or so, worst case. (you can look at the various cell testing charts at Flashlight information for examples of cell response under various loads for various kinds of cells)
So you need a better battery...or try several toolpacks (charged to identical voltages) in parallel and see if the voltage sag is lessened to acceptable levels.
Probably need a clamp-on ammeter, or a wattmeter like these: https://www.amazon.com/dp/B013PKYILS
FWIW, I melted teh shunt off a "free" harbor freight 10A multimeter trying to use it to measure current on this kind of thing before I got a wattmeter (first an old well-used WattsUp, then a Turnigy Watt Meter, which is a cheap clone of the WU, and now there are hundreds of even cheaper clones of the TWM....).
Nowadays I use the Cycle Analyst for this kind of thing; it has a shunt (like the one linked above does) that goes in series with the battery-negative-to-controller (motor in your case) wire to measure current, and is powered from the main battery so it can monitor volts, watts, etc. Unlike most of the cheap wattmeters, it also remembers the various stats after losing power (when the battery dies or system is switched off), so you can repower it later and find out how things performed. :)
Yup your pretty bang on. I looked up some specs on my craftsman batterys seems every 2ah increase in battery size is an additional 5 cells. each with a nominal voltage of 3.6v. I normally run a 4ah battery and I have a 9 amp hour on the way wich should perform much better. The strain on the cells should be cut in half with each increase in battery size or no? That analyst sounds super nice, the multimeter worked pretty well for voltage at least. I have a phone holder on my battery pouch that fit the multimeter nicely haha.
Sounds like I probly won't find a controller that will work with a drill battery haha. I saw a couple simple ones that were 12-24v and supposedly worked for higher voltages.
I just went on another ride with a fresh button and it worked great, diddnt even heat up. Coming back with 50pds backpack from the grocery store up slight incline. I was riding very hard the day it melted and was doubling with my son on the bike going up a slight hill without pedaling. I had fried a couple other buttons in the past getting to this point but they were not great quality and tiny contacts. As long as I'm pedaling a bit and aware It should last till I figure out a controller.
I use these batterys for everything from powering my kids 4x4 and motorbike ride on to heating elements for camping sand batterys and even a winch and the thing that seems to strain the battery and drain it the fastest is the craftsman 20v grinder I have. Even the 20v chainsaw runs forever on 4 ah. I'm super impressed with the power and logevity of even the 2ah batterys
There's applications where controllers are unnecessary. Yours might be one of them.
Burly switches are also optional ... in that you can use cheap ones and treat them as disposable, e.g. buy a box of 15A toggle switches at the local trash and treasure market for a buck a piece, that come with integrated male spade connectors so that you can swap them in and out every week in a matter of seconds.
Wow I need a trash and treasure market in my hometown 😁 I got 2 heavy duty 20amp buttons on amazon for around 12$ and they sell 50 amp ones for a bit more. Think the 50s would hold the heat better?? It almost is perfect as is, just got to keep an eye on the heat
Impossible to say. No name cheap switches, no data sheets, invented ratings, they could be good, great, horrible, who knows.
Key determinants are contact area, contact material, and contact (spring) force. The only switches worth considering must be spring loaded, with a lever to provide leverage (reduce required activation force).
This is easy enough to achieve with rotary and toggle switches, but don't think I've ever encountered anything in a push format that meets those criteria.
So, I I think you just wasted $12, sorry to say.
If you want low activation force, use a relay activated by a fifty cent push button. The relay provides the spring force that your push button can't.
Alternative is DIY. Two copper strips sprung apart in some way, encased in section of bike inner tube, squeezed to activate. Use fine grit sandpaper and WD40 to clean the contact surfaces every now and then.
You could make it cable operated by a bike brake lever if you like. Even use brake calipers with copper blocks instead of pads.
There's no magic in switches - you can make your own.
I like your thinking haha! I'm all about the janky diy stuff I was thinking of trying something similar. I love the brake lever idea maybe there's a way to make that look clean. i want to make this same thing for friends and family so they can run their bikes on thier drill batterys, so cant be too janky lol. Everyone that tried it wants one. How would the relay activated button be wired to keep the button from frying? I could find a relay that can be activated by a lower signal voltage wire or something? I'm fairly new to electrical tinkering.
The 20 amp button i got from Amazon seems to work fine as long as it's just me on the bike and I pedal uphill. I had me and my kid on the bike (about 250lbs together) up a slight hill and not pedaling for about 5 mins when it burnt out. The button is massive at about 3 inch long and 1 1/4 inch across and pretty good size terminals. The button is very hard to push for a long time my thumbs are definatly sore after a ride lol. Seems silly the activation force needs to be so high i was thinking I could replace the spring inside but no dice, can't be taken apart.
Do you have bulk trash that gets put out and picked up periodically? Junkyards? A local trashdump? Thrift stores? Yard sales? Craigslist, TrashNothing, Freecycle, etc? There's often lots of places to get great deals or even free stuff with parts you might be able to use....
The catch with many parts is that they can print whatever ratings on them they want, whether or not they are actually capable of whatever rating says it is. :(
If you link to the specific items in question we could give you a better idea, but when I did a quick search on the terms you've previously used in this thread, the stuff I found was stuff like this:
Of the switches I've had like that (and similar plastic ones), none of them were built as well as they said they were, none were even water resistant much less IP67 :lol: etc. Never tested them for extreme current as I only needed them to turn a light on, or a fan, or some other thing, but I doubt they would have handled the currents they said they would.
That doesn't mean that there aren't "real" ones, but you should be aware there are ones that are essentially fake, in that they aren't actually what they say they are--this is true of every category of part or item you can buy. :(
As long as the wiring is neat. Use Heatshrink rather than electrical tape. Relay's the more "professional" option though, and let's you have the power path from battery to motor nice and short.
You only need thin wire up to the handlebars for the button - but can be practically anything, whatever you have laying around, coax, Cat6, lamp lead, USB cable, etc.
Button will only carry one or two hundred milliamp, just enough to power the relay coil, so won't even get warm. You can use a tiny little switch, so almost no thumb pressure required.
A 24VDC automotive relay ($5) will typically not activate below around 18V. The dropout voltage is lower, meaning once you've activated the relay it'll remain closed until the voltage drops below 15V or lower. However, the dropout voltage is problematic for you if you intend to run the battery til almost flat.
You'd be better off with an 18VDC relay from a proper electronics supplier. They're available, but specialist items, so not in physical stores, need to source it from online supplier.
Alternatively use a 12VDC relay, with voltage from battery dropped to close to 12V. Again, as with 24VDC, the mass produced automotive ones are the best value at about $5.
It's added complexity though. Personally I'd explore ways of making my own switch mechanism. And ones that don't involve thumbs. Something like a regular twist throttle.
Sounds like my power output and speed would be effected as well. I'll look for an 18v relay.
So any relay will work and just wire the button to the relay. Wont need separate signal wire terminals built or anything?
The amazon link wasn't available in my area. The pics don't look like the one I have though. This one seems well seamed from the elements and good contacts but partially plastic housing that melted previously.
Knife switch?
iu
DIY:
There is something refreshing about this thread, back to basics, love it!
Wire battery negative to the motor as you already have. Wire battery positive to the relay C (common) contact. Wire motor positive to the relay NO (normally open) contact.
Now also wire battery negative to one pin of the relay coil. Wire battery positive to one pin of the switch. Wire the other pin of the switch to the other pin of the relay coil.
When you press the switch it will put battery voltage across the coil, which turns the relay on. The relay then closes the NO contact to the C contact and applies battery positive to the motor that alreayd has battery negative, and VROOM.
You only need an SPST (1P1T) relay, but you can use any of them (SPDT, DPDT, 3PST, etc etc).
If possible, the relay coil voltage should match the nominal battery voltage. A 15v-coil relay should do that; they're not uncommon.
If you use too high a coil voltage type of relay, it could drop out (turn off) whenever the battery voltage drops under load. That can actually be used as a feature, if there's enough hysteresis in the relay, as a form of LVC so if the battery drops too low it would shut off the system long enough for you to let go of the button. If there isn't, the relay will just chatter, which can damage the contacts or weld them shut (system stuck on).
Too low a coil voltage and it will get hot, which may just deform the relay casing but too hot and it'll damage the coil insulation, or actaully burn out the coil. As noted in another post you can use a resistor (few hundred ohms or less usually) to lower the current in this case; probably a 1/2watt type.
The contact votlage of the relay can be anything as high or higher than your full battery voltage, to guarantee proper break of contact under full load, without damage to the contacts or welding them together during make or break or potentially even arcing across and causing operation when the relay is *off*. (that last is highly unliklely at the voltages youre using, but the others are possible).
The current rating of the relay can be anything as high or higher than the amps you measure ;) between battery and motor under worst case load (max weight up steepest slope). If the relay is not high enough current rated, then it'll have the same problems the switch does, for the same reason.
In theory you can parallel relays for higher current, but in my experience they don't switch at exactly the same time so sometimes the faster switching one gets contact damage over time and can fail first...but this can take a lot of cycles at high current to happen, so...it does work. So if you needed 100A you could use two 50A or three 40A or four 30A, etc. As long as the total is higher than you need....
Most automotive "12V" relays can easily operate at 15v for coil voltage, and they might handle the 20V battery voltage alright. They make them in at least 30A types (I use some of that size in SB Cruiser to switch lighting, etc).
The ones I use have fuseholders in them with blade fuses preinstalled, so if they see a current higher than they can hanlde the fuse blows, protecting the wiring and the relay and the devices that haven't yet failed (to cause the high current ;)) that are powered by it. https://www.amazon.com/dp/B01NBAO1SA The wiring diagrams below are two ways you can set up your system to work; "trigger" would be your button/switch, wired between the trigger wire and the other battery wire.
They do look quite a bit better designed for weatherproofing than the type I showed. I have seen somewhat similar-appearing ones used on aircraft cockpit panels in scrapyards (don't know which aircraft but something small, one or two seater).
Knife switch?
Here's the "controller" version of that, though it's not the big version that would handle the current needed for this system. (the big version is about twice this diameter and took both hands for me to hold and lift; I can't find my pics of the one I used to have, or any online images of them still around).
NOS Vintage Superior D1000R Variac 1000W 8.3 Amp Luxtrol Light Control 8A 120v
Sub 32 volts is a good range for getting DC solid state relays that can push lots of current. In your case, that's what I would try. If you think you'd like actual speed control, there are good cheap PWM controllers to do what you are doing, but I like the idea of TURBO button only. It goes with a BMX bike.
Amazing thanks for all the helpful info! I'm going to try the relay wired as you suggest and see how that works. I'll see if I can find a 15v one.
Solid state relays can handle more current? I had 2 pwm controllers and they melted even though they were rated 72v or so, however they were cheap. they just have a knob to adjust the power and a button to controll so hard to work both at once. I am liking the turbo button as well lol only problem is the wheel shifting (chain loosens) at stop or low speed and a lot of strain on the system.
I could just wire a ebike throttle in place of the button (switch) as long as I'm using a relay so the throttle wires arnt taking the load?
They all have ratings, though I would not expect cheap Chinese ones to deliver 100% of their rating.
If you use something designed for a brushed motor scooter, it will do what you want (up to its capacity). Anything that has cooling fins on it needs airflow to stay cool, so don't wrap it up or insulate it from ambient air.
I use a 20 or 25 amp PWM controller feeding a Heinzmann brushed hub motor on my sidecar bike. It's rated 36V, but it works fine with 44V batteries.
No, if you want to use a throttle, you have to use a speed controller. A relay or a solid state relay only uses an input voltage to turn it on, and for that you need a switch, not a throttle.
Well, a relay is just a remote controlled switch, so it is just on and off. If you are using a resistive (potentiometer) throttle, it could be wired to activate the relay when it is rotated far enough, essentially all the way on, but it wouldn't give you any variable control.
If you want variable control, you have to use the cheap small light controller for your type of motor (brushed) like those I pointed you to originally, instead of the relay.
Or one of the huge bulky heavy lighting controls or other rheostats (giant wirewound potentiometers, basically). ;)
Or, if you were willing to open up your toolpacks and connect high-current wires to the individual cells, you could build a relay-controller. Old forklifts used to do this by using stacks of relays to connect and disconnect batteries in series with each other to get more voltage for more power and/or speed. To do it for your batteries, you'd have to open the toolpacks up be able to access the cells for individual charge and discharge. (you won't be able to charge them with the bulk charger anymore, you will have to individually charge the cells, because they will no longer be anywhere near balanced when used this way; the cells closer to battery negative will have successively greater discharge.)
Or you can build your own PWM controller (the same thing you can buy cheaply) from various circuit diagrams on the internet and scrounging FETs and opamps (LM339, etc) out of unused old electronics.
