warrah
I'd say you definitely need a relay to get what you want; both levers ebraking, both levers brake lighting. The relay you need is the one amberwolf mentioned, a 12v STDP relay. You dont need to know the type of controller before you start. This is because the 12v circuit, closed by the brake levers, will activate the relay, which in turn will simply close the controller ebrake circuit, much like the controllers ebrake circuit would be closed by a brake lever if we were wiring an ebike the ordinary way. Once its closed ie once the two ebrake wires coming off the controller are bridged, the ebrake signal is activated. We could touch these two wires together however we wanted, using any sort of switch we liked, or just by touching the ends of the wire together. Doesnt matter what kind of controller.
This is quite a universal procedure, you'll be replicating the way its done in motorcycles (theres loads of relays in motorcycles), so a guide for everyone would be awesome.
buy one just like this, but from somewhere cheaper:
http://store.acradiosupplyinc.com/nter25-5d16-12relay-16amp-dc-12v.aspx
i found an example of one with translucent plastic, because its useful for understanding whats actually happening in the circuit youre making. You can see the switches being pulled by the electro magnet, its really cool.
I should mention that you'll be doing some soldering, so grab a 40w soldering iron, or a 60w if you are impatient like me. Its a great project to practice with, very achievable.
